How to hook up a I/O Magic External DVD Writer? How do I tell if I am missing a card or a driver?
You don't need a driver, Window Xp & above will already have a driver for it. I also have the same DVD writer. Now if you don't have Xp, Than I don't know.......
It should work in windows 2000,Xp or vista by just plugging it in.If you have windows 98 you will need a driver. If yur drive came with a disc it should have it on there. Most of these external usb drives do include 98 drivers if not check their web page.
Thank you very much for reply. I have just started using this site and it looks good for "Dummies". When I try and set it up I get message #1-Dose Not Find: USB 2.0 TV Box and message #2 File Needed: file 'StkAMini.sys on USB 2.0 TV Box Driver Disk is needed. Driver CD that came with unit will not load. - MillieOriginally Posted by Marvingj
Thank you very much for reply. I have just started using this site and it looks good for "Dummies". When I try and set it up I get message #1-Dose Not Find: USB 2.0 TV Box and message #2 File Needed: file 'StkAMini.sys on USB 2.0 TV Box Driver Disk is needed. Driver CD that came with unit will not load. - MillieOriginally Posted by buttzilla
[quote="Mildred327"]
Thanks again. I took it back to Circut City, FireDog,their teck help. The external writer worked fine with their CPU. A driver needed an update in mine. And it worked fine. I have not used it yet at home but will today. I am Windows XP, version 2002. Sincerly, - MillieOriginally Posted by buttzilla -
Go to the site and get a driver...
http://www.iomagic.com/Products/show_all_results.asp?Category=6&ProdID=IDVD12D -
Thanks for the URL. I may not need it but nice to have handy. Hooking up anything on/to my computer is very daunting to me, any how. Sincerely, - MillieOriginally Posted by Marvingj
External DVD writer to deal with CRCs
By ringo12 in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Nov 2009, 05:17 -
What's Better? DVD Writer or External Drive for DVR
By DerbyDad03 in forum Newbie / General discussionsReplies: 8Last Post: 16th Apr 2009, 18:01 -
External dvd-writer
By Pablo2k1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Jan 2009, 13:29 -
Best External DVD Writer
By poppy56 in forum DVD & Blu-ray WritersReplies: 6Last Post: 5th Feb 2008, 14:19 -
Speed on External DVD Writer
By mn072065 in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Sep 2007, 16:45
