Hi
With my SD camcorder I would use FireWire+WinDV to transfer the videos onto the PC. I could then take the .AVI files edit them with just about any software, then compress them to .MPG to share them.
Now I've acquired the HD Sony HDR HC 7 which uses the HDV format. I used HDVsplit in the same fashion I would have used WinDV and now the files are on the PC as .M2T format. Question now is what software can I use to edit them (Vegas?) and what options do I have for compressing them so that I can share them (email clips etc)? I'd prefer it if the compression keeps things hi def. TKS in advance.
Thread: Compressing HDV format Etc?
Yep, you can use Vegas see http://forum.videohelp.com/viewtopic...563546#1563546 and export to wmv if you want to share it.
OK thanks. I wonder if WMV can be easily changed into whatever Blueray/HD-DVD use, in the same way I take my MPEG2 SD files and create a DVD with them. I assume you mean WMV-HD BTW.
Is there generation loss in HDV format??
By 392 in forum EditingReplies: 8Last Post: 13th Jul 2010, 13:59 -
Help with incompatible video format, HDV
By LaMaison in forum MacReplies: 6Last Post: 21st Dec 2009, 05:00 -
HDV intermediate format for Mac
By kippard in forum MacReplies: 2Last Post: 24th Jun 2008, 08:14 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 19:31 -
problem with compressing HDV clips on Mac?
By elizavetaka in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 14th Oct 2007, 23:38
Statistics
Newest guides
Latest tool updates
New media comments
