Yes, as the subject says, plus.. if WIN98 (and XP, case I do any 'post' writing for forums)
doesn't have such a font, then is there a D/L 'able one from VideoHelp or other place ??
I ask because I want to set my WIN98 wordpad to it.
Thank you (VH) for all the great work and features this forum board offers.
-vhelp 4258
I think it's Verdana.
Great, that did it.
FONT: Verdana (West)
I'm using Opera, and although I'm not sure what 'zoom' setting I have,
(you know.., when you press -/+ keys) the screen window re-sizes text
and images, accordingly.
fwiw ...
If you (or anyone, that is) what to get a 'standard' view for Opera,
you do this:
A - press the '-' key as many times until the screen stops sizing down.
B - press the '+' key 8 times. This will give you a 'standard' font
size view, assuming your font is set 10 size.
Now, when you use the Verdana (west) font, and its set to 10, you can
get an exact look of what you are typing in wordpad vs. VH forum posts.
-vhelp 4259
Or just press "6".Originally Posted by vhelp
hmm.. you are correct. Thank you for the tip.
-vhelp 4260
Visiting VideoHelp Forum
By Bonie81 in forum FeedbackReplies: 5Last Post: 15th Feb 2012, 09:55 -
Time of front page forum posts
By KiwiKid in forum FeedbackReplies: 2Last Post: 24th Dec 2010, 12:20 -
forum font colors
By lordsmurf in forum FeedbackReplies: 2Last Post: 26th Jan 2010, 15:42 -
Posts to Off-Topic Forum Visible On VideoHelp's Home Page
By usually_quiet in forum FeedbackReplies: 1Last Post: 26th Jan 2010, 11:25 -
Logging in and making posts.. is forum going.. [SOLVED]
By vhelp in forum FeedbackReplies: 17Last Post: 25th May 2008, 20:06
