Can that be done?
Not easily.
Google your box model and see what the hackers say.
Usually anything they can do requires a box from the SAME system.
Originally Posted by oldandinthe way
Been there done that. Not much on that subject. Thanks anyway.
The only mod I have seen it is kind of complicated, and not intended to make your cable box work with other companies. Some knowledge of electronics and computers is required, because a chip in the box is removed, and replaced by a flashed one ( the firmware is reprogrammed using a computer connection to a printed board).
No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. ..
Modern boxes are programmed directly over the cable from the cable company. Talk to them.
Already talked to my cable company and to the manufacturer of the cable box. They both said that I need to contact the company that has the serial code of that box on their list. Problem is, I don't know which company it is, I'm not even in the same country where that cable box came from.Originally Posted by edDV
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / HDTVReplies: 84Last Post: 18th Jan 2012, 06:04 -
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 13:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum CapturingReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / HDTVReplies: 11Last Post: 28th May 2009, 12:21 -
Testing with a digital converter box on a cable system.
By 389poncho in forum DVB / HDTVReplies: 36Last Post: 6th Jan 2009, 19:18
