I have Sony Click to DVD on my computer and I noticed that in the settings window, it lets me chose to capture in DV or MPEG. Now I want to know which video type will give me the best quality. I know DV is gonna take some more room, but I would like to know which gets better quality. Note, we have standard televisions in the house.
Thread: DV vs. MPEG
DV transfers to the computer in full quality. The computer can then take time encoding to MPeg2 as needed.
Capturing to MPeg2 requires a fast CPU to make the conversion "on the fly" Even if the CPU is fast enough the quality will still be less because less time can be used for the encode.
Try it both ways and see what you think.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Thanks. And I saw that my computer also has a program called DVgate Plus. Is that like WinDV sortof? It says that it can capture DV from a camcorder.
Also, if you intend to edit or add titles, effects and transitions, DV is the better way to go. While there are now some very good mpeg editors that can do many of these things with minimal re-encoding, you cannot escape the fact that mpeg does not like being encoded multiple times, and things like transitions are the worst because they require high bitrate to get right in the first instance.
DVGate is a Sony App. It works. I like WinDV for simple transfers.Originally Posted by videoboi
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 8Last Post: 8th Nov 2010, 14:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video StreamingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
