I started getting an error message at random intervals. The message is:
Exception Processing Message c0000013 Parameters 764ebf9c 4
I recently used Partition Margic to combine 2 partitions of hard drive, so now the E partition desn't exist anymore. Is it possible that this error message is related to the combining of the hard drive sectors? How can I get rid of the error message? It is annoying and it makes a short noise every time it appears. It doesn't seem to affect computer operation however.
I Googled the problem but could not get any clear idea what to do. I am a newbie, so I need detailed explanations. I have xp.
What this usually means is that you have an application that is causing and exception error.
Most often the cause is a virus or other malware.
Use Hijackthis and post the results on http://www.techguy.org/
an expert will tell you if anything is amiss.
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
Help. Avisynth Error Message "no function named limitedsharpen"
By Pitorasilo in forum Video ConversionReplies: 7Last Post: 27th Dec 2010, 06:13 -
Help. Avisynth Error Message "no function named deblock"
By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 27th Sep 2008, 23:45 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
Statistics
Newest guides
Latest tool updates
New media comments
