    Please help. I captured a VHS tape with my DV cam using this guide: http://forum.videohelp.com/viewtopic.php?t=244151
    I compressed the file with VirtualDub [Video: DivX / Audio: Lame Mp3, 48,000 Hz, 128 kbps CBR stereo, 16kb/s]
    When I play the compressed avi, I only hear sound on the left side. How do I make it on both sides? I eventually would like to put it in a DVD.
    Does the original DV file have audio in both channels ?
    Why, if you want to put in a DVD, did you then compress it to Divx ? You are throwing away a lot of quality this way. keep it as DV until you need to encode it to mpeg-2 for DVD.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Hi guns1inger... Thank you for your reply. OMG, had i only known, i would have encoded right away while it was still a DV file. I did the "capture" long time ago and didn't have enough HD space to store the file so I compressed and burned it as a CD data file. Now I am encoding this compressed file so I could burn and create a DVD out of it. Unfortunately, wasn't able to check whether the original DV had both channels. So is it still possible to make the sound heard on both sides with this compressed AVI?
    Open the file in virtualdubmod and click on Streams->Stream List. Click on the audio track, then click on Demux to save the audio as a separate file. Open this file in an audio editor and copy the left channel into the empty right channel. Save this as a wav file (uncompressed PCM audio).
    Open the avi file Virtualdubmod again, and click on Streams->Stream List. Click Add, and select your new Wav file. Click on the mp3 audio track and click on Disable, then OK. Finally, click on File->Save As and save a new version of the avi with the fixed audio. Make sure your mode is set to Direct Stream Copy.
    Thank you so much, guns1inger. It worked! I'm glad I asked here^_^ Btw, I used audacity to edit the software. And if anyone needs the tutorial (for audacity), here it is: http://audacityteam.org/forum/thread/4567
  1. mpeg file has sound only coming on left side...
    By matvangogh in forum Video Conversion
    Last Post: 16th May 2006, 13:38
  2. line down the left hand side
    By browser in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Sep 2003, 11:26
  3. Movie is on the left side
    By mephoneno in forum Authoring (VCD/SVCD)
    Last Post: 29th Aug 2001, 04:21
  4. Sound from left side?
    By ckxd69 in forum Editing
    Last Post: 27th Aug 2001, 23:45
  5. Please help - TV cuts off 10% of the left and right side of
    By marquard in forum DVD & Blu-ray Players
    Last Post: 14th Jul 2001, 07:02
About   Advertise   Forum   RSS Feeds   Statistics   Tools
