I used CamStudio to record a 26min clip. In the process of converting to .avi after ending the recording, CamStudio crashed.
I am left with 2 .wav files. I can retrieve the audio recording from the smaller .wav file (270mb) and retrieve the video recording from the other .wav file (3.91GB) using MediaCoder and VirtualDub. Is there any way for me to merge these two files into 1 single .avi file?
Results 31 to 37 of 37
Hm,
I remember using an obscure program for this with some strange name.
Still, VirtualDub should be able to do this.
Try merging the files, audio and video, with this solution:
"Open the video file you want and select 'Audio - > No audio' to remove the audio (1) or 'Audio -> WAV Audio...' to load a wav file in your video (2). Then you can select the video and audio codecs and save your final video file."
Source: from some person on this site
http://www.my-guides.net/en/guides/general-video/99-how-to-cutsplitmergeeffectaudio-vi...ing-virtualdub)
Cheers. -
I have tried all of the Below and so far only formatfactory worked but it only recoved like last 15 seconds of the video.
The complete Clip is 26mins and is 4GB. This is a VERY important presentation and i really need help to recover this. -
I VirtualDub was only able to read the last 20 seconds of the video. FormatFactory and MediaCoder don't work. Duration of the video is 21 mins from CamStudio. Please help.
The answer is Format Factory!! I had a video i needed of a motor vehicle accident and it was corrupted as the video stopped without shutting down and closing the file. Nothing would open it. Format Factory did easily in seconds. Thank you thank you donation on its way. http://www.formatoz.com/
isn't format factory just a basic gui for mencoder&ffmpeg ?
Corrupt M2T file, how to fix?
By El Mariachi in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 6th Mar 2011, 15:53 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 15:40 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31 -
Can I fix this? (was: Tivo transfer/corrupt file)
By trimicada in forum Newbie / General discussionsReplies: 3Last Post: 23rd Oct 2007, 19:05 -
Corrupt AVI File
By thankyou in forum Video ConversionReplies: 35Last Post: 18th Oct 2007, 02:19
