I've been researching all the how to guides for audio sync fixing that I could find. I found a guide using Media Player Classic and adjusting the audio delay. I have a AVI that I ripped and has several points with different syncing errors. I figure I can find the first out of sync instance and determine the delay time in MPC , then move on to the next and so on and note them down. Then I would split the original AVI using those adjustment time points as the start/end points for the split --> then take each AVI segment and adjust the audio delay in MPC and lastly join them all together again. I have Boilsoft's AVI-MPG-ASF-WMV splitter and joiner software. I type in the exact time stamps to rejoin all the segments, but when I view the complete AVI, the movie skips, I guess is the best way to describe it, when it passes the joined timestamps. Kind of like even though I enter the exact time to start the split, the program keeps a mili-mili second of video before the time that I typed in resulting in that skip on the final. It seems to be doing this. I want it to start the split 01:12:03:004, but it actually splits at: 01:12:03:002 and that difference causes a slight jump in the final compiled edit.
Is there a program(s) that is super precise in actually splitting and joining at the exact time I give it. I think that this method works for me pretty well if I can get the skips out.
Thanks,
Jerold
The latest virtualdub does smart rendering, as does AVIDemux, so you should be able to cut precisely without having to re-encode everything.
Does virtualdub and AVIdemux split the video or just the audio? The boilsoft programs that I have is having issues with the video splits.
Both. I don't know of any free editor that allows for simple editing of an audio track in place.
avi/mp4 splitter with good precision and fast movie preview
By maradas in forum EditingReplies: 4Last Post: 6th Mar 2012, 19:04 -
Poor man's 5.1
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2010, 07:53 -
TVNow – hacking it into a poor man’s video Ipod
By David K in forum Video ConversionReplies: 10Last Post: 20th Jun 2009, 17:18 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video StreamingReplies: 1Last Post: 14th Jul 2008, 00:25 -
Poor Man HTPC
By mz_ in forum Media Center PC / MediaCentersReplies: 9Last Post: 28th Feb 2008, 17:21
Statistics
Newest guides
Latest tool updates
New media comments
