VideoHelp.com Forum
    Hello,
    I am new to all this dvd burning lark and am not sure what I am doing wrong. I have some AVI files which I want to burn to dvd and watch on my dvd payer. I originally done this using the DvX codecs and DivX dvd burner, but they won't work as my player does not support DivX movies.
    I have since tried using Video DVD Maker Free but it says I don't have the correct codecs! Any tips???
    ConvertXtoDVD to convert the avi files to DVD.
    One movie per disc.
    Burn with ImgBurn.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    One movie per disc.
    Burn with ImgBurn.
    Thank Gunslinger - are there any free programmes that I am able to use for this?? I thought Video DVD Maker would be able to do it as it says it can?? Also, any way I can put more than one onto a disc? Each oe is about 45 minutes long, 350MB...
    DVD Flick, AVI2DVD, TheFilmMachine are all free. ConvertXtoDVD is just incredibly simple, fast, and covers a much wider range of source material. If you mostly have Divx/Xvid avi files then any of those listed above will work.
    45 minutes episodes - you can probably go to 4 without overly compromising your quality (given the quality is only OK to begin with). Be prepared for all the flaws that aren't as obvious on your PC to become very obvious when you convert. There is little you can do about this, other than to get better quality source.
    Thanks Gunslinger - will give it a go. Having looked at the reviews, am going to crack on with DVD Flick.
    Heres hoping, and once again - thanks!!
  1. Burning some WMV and MKV files to play on a DVD Player
    By marnisper in forum Newbie / General discussions
    Last Post: 7th Oct 2011, 08:24
  2. burning divx files as data to play on dvd player
    By penguyen in forum Authoring (DVD)
    Last Post: 30th Jul 2011, 10:54
  3. why will some avi files play in my dvd player while others will not?
    By panman36 in forum Newbie / General discussions
    Last Post: 8th Nov 2010, 10:58
  4. Burning HDV AVI to DL-DVD to play on BR player.
    By suppafreak in forum Authoring (Blu-ray)
    Last Post: 6th Oct 2009, 19:25
  5. DVD player to play .avi files
    By micallen in forum DVD & Blu-ray Players
    Last Post: 23rd Nov 2007, 14:14
