I am posting to seek additional assistance in the converting of a DRM M4V Video Clip.
Recently I searched the Internet via Google and turned up Tunebite Platinum with
MPEG-4 Decoder which will convert M4V protected files to an uprotected file.
The issue I am having with Tunebite is it requires a min of 2GHzs Processor to convert
M4v, I only have a 1.79GHzs which is not enough to perform the conversion.
I wish to know is there any other software other Tunbite which will convert a M4V using
my present processor.
JEG
Hi,
Tunebite is the only option I know of at this time, have you actually tried it with your processor? It uses 3ivX as a video Codec which traditionally is not a really power hungry Codec, Perhaps decoding the H.264 to convert is why you need the CPU, anyway you are not that far off spec, I'd try the demo anyway. The only other (very crude) option would be to playback the clip from a iPod (Video) using the TV out into a capture card or DVD recorder.
Tunebite 7 Help Screen Capture Wizard
By mn072065 in forum CapturingReplies: 5Last Post: 27th Dec 2010, 10:35 -
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum CapturingReplies: 4Last Post: 27th Dec 2010, 09:26 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
Tunebite vs SoundTaxi
By weavejenn in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2009, 04:19 -
Tunebite video settings..is anyone out there familar with tunebite?
By cduval04 in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2007, 16:41
Statistics
Newest guides
Latest tool updates
New media comments
