VideoHelp.com Forum
  1. I record several segments to the HDD of this unit then burn a DVD. When i try to rip the dvd onto a computer for more editing I cant do it I've tried several programs and with some I can actually rip the video but the resulting MPG file always shows to be 9 hours long with a frame of the menu at the end so my editing software ulead and womble both freak out on the file and crash
  2. Member hech54's Avatar
    1) Is the disc finalized?
    2) Rip it with DVDDecrypter, IFO Mode, Stream Processing, uncheck the menu(I think it actually shows up as a subtitle?). If you are doing further editing you may also want to consider File Splitting NONE as an option as well.
    3) Run the ripped material(whether you used Option 2 or not) through FixVTS?
  3. Thanks Works great............
  4. Member lacywest's Avatar
    good info
  5. Member hech54's Avatar
    I get lucky every now and then...
  1. Polaroid DRM-2001G...
    By Senex in forum DVD & Blu-ray Recorders
    Last Post: 12th Nov 2010, 17:57
  2. DVD Recorder: Polaroid DRM-2001G tests
    By vhelp in forum DVD & Blu-ray Recorders
    Last Post: 14th May 2010, 10:32
  3. polaroid model DRM-2001G
    By supercat111 in forum DVD & Blu-ray Recorders
    Last Post: 14th Jan 2010, 21:03
  4. Polaroid DRM 2001G
    By jb1wohrrcom in forum Newbie / General discussions
    Last Post: 7th Apr 2009, 12:49
  5. Comments on Polaroid DRM-2001G DVD Recorder
    By DJL82 in forum DVD & Blu-ray Recorders
    Last Post: 12th Oct 2007, 01:42
