VideoHelp.com Forum
  1. I put TMPGEnv plus 2.5 in my new PC w/ Vista Home Premium and when I compress to Mpeg the picture is black. What can I do?
  2. Member SanderMan's Avatar
    You could try to install ffdshow and after that give the directshow filter a higher priority in options->environmental settings.
  3. So by installing ffdshow it might make TMPGEnv plus 2.5 to able to read the AVI DV file?
    It might.
    You'd still have to enable the dv decoder, I don't think it's automatically enabled.
    You might want to give the canopus dv codec a try first.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    It's likely just a codec problem as mentioned. I use TMPGEnc Plus 2.5 encoder with Vista with no problems. I don't have any DV sources available at present to test it with them.
    I do have ffdshow that is part of the Vista Codec Pack installed. I don't usually install codec packs, but this one seems to work fine with Vista and causes no problems otherwise. http://www.msfn.org/board/index.php?showtopic=66826
  1. VCDEasy doesn't work in Vista...
    By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)
    Last Post: 26th Dec 2010, 20:20
  2. FAVC does not work in VISTA !!!
    By gonwk in forum Newbie / General discussions
    Last Post: 1st Mar 2009, 03:48
  3. Replies: 6
    Last Post: 7th Jan 2009, 17:53
  4. Doesn't work with Vista SP1
    By hordak in forum SVCD2DVD & VOB2MPG
    Last Post: 14th Mar 2008, 15:19
  5. Does TMPGenc Plus 2.5 work on Vista Ok?
    By leegutcher in forum Newbie / General discussions
    Last Post: 6th Jul 2007, 07:22
