VideoHelp.com Forum
Results 1 to 9 of 9
  1. i want to buy a remote control to control itunes in my pc as well as movies being played, i have a desktop and it would be nice to have one, any suggestions? ohh yea and something in the cheap end.
    thanx
  2. Member Krispy Kritter's Avatar
    The only remote I'm aware (and I'm sure there is something else), is the remote for the AIW cards. Support for the remote is built into the AIW TV/media player software.
    There is also support for a remote in XP Media Center Edition. The bottom line is that remote support is part of a software package (usually based on TV/media playback). I don't believe windows on its own supports remotes.
    Google is your Friend
  3. Member dphirschler's Avatar
    You can build an IR transmitter/receiver for around $20. Then you can use any remote you have around the house with free software or shareware and payware. I am using my Pinnacle remote (only because I had one and it came with an IR receiver) along with IRAssistant free software.
    Darryl
  4. Free Flying Soul liquid217's Avatar
    How about a mini wireless keyboard?
    http://store.pcpowerzone.com/01wimikewiop.html
  5. two questions, what a pinnacle remote you are using?(what is a pinnacle remote?)
    Whats best? RF/IR?
    do you have any links that work to build my own RF/IR receiver?
  6. Member dphirschler's Avatar
    Whats best? RF/IR?
    I am using the Remote that came with my Pinnacle PCTV PRo capture card. It looks like this:
    http://www.viaarena.com/htmlimages/remote.jpg
    The IR receiver connects via serial connection. It looks like this:
    http://www.viaarena.com/htmlimages/extreceiver.jpg
    Check out www.lirc.org for schematics (and more information) to build your own IR receiver. Here's one schematic:
    http://www.lirc.org/images/schematics.gif
    Hope that helps. Good luck and please report back with your findings. I haven't looked at this stuff in a year or so.
    Darryl
  7. so i went to radioshack and they didnt have the IR receiver and other parts like the resistors could only be sold in 10 packs. i figured it might be easier to buy a remote and tuner card or buy from this lady who makes them.
    http://lnx.manoweb.com/lirc/?partTyp...n&partName=buy
    but i have one question, if i plan to use IR assistant will i be able to use itunes and other not well known programs (Gom player)
    any suggestions of a good remote/AIW card im kinda concerned that if the card fails i wont be able to use the remote cuz its got a special connection not serial
  8. Buy yourself the ATI Remote Wonder, it is programmable and does not require the ATI MMC to work. You can buy it separately. It is an RF remote and works through walls. I have two and use it on multi media center via win xp pro.
    The ATI remote has a speparate USB reciever and is not dependant on the AIW card. You can buy the ATI PCI TV WONDER CARD 550 for like $49 with a free MIR for a remote as well.
  1. Remote control WITH timer
    By rdbierma in forum Newbie / General discussions
    Last Post: 9th Mar 2010, 15:54
  2. ATI remote control
    By lazybum in forum Capturing
    Last Post: 12th Jun 2009, 17:19
  3. Universal Remote Control
    By titilucky in forum DVD & Blu-ray Recorders
    Last Post: 3rd Nov 2008, 14:31
  4. Remote control for VBox?
    By slytrans69 in forum Media Center PC / MediaCenters
    Last Post: 15th Aug 2008, 15:53
  5. remote desktop control
    By pcb in forum Computer
    Last Post: 9th May 2008, 06:00
