VideoHelp.com Forum
    edit: The problem was that I didn't have AC3Filter installed because I thought ffdshow would give AC3 files a graph for rendering but that was failing for some reason, maybe I'm on a buggy build of ffdshow?
    Either way I installed AC3Filter and all works now, but at the same time let me go and get an older build of FFDshow.
  2. Member Soopafresh's Avatar
    Are you using an old HC.INI file which specified the start and end frames of the previous file you ran it on ?
    BTW, try out the 2.0 to 5.1 AC3 upmixer script:
    http://forum.videohelp.com/viewtopic.php?t=326127
    Also, try this Mplex syntax (not that'll help, but it might)
    mplex -f 3 -s 2048 -h -V -v 0 -b 896 -o output.mpg input.m2v input.ac3
    Thanks, the process was working fine, the problem was with the media player not being able to establish a directshow graph to play back the AC3 stream, I dont know what was playign the AC3 file directly before, but from inside the mpg stream it just wouldn't play (GSpot was what led me to this conclusion).
  1. .m2v + .ac3 + .sub/.sub to .mpg
    By stevie99 in forum Video Conversion
    Last Post: 9th Apr 2012, 03:01
  2. Replies: 61
    Last Post: 3rd Mar 2012, 15:13
  3. NTSC/PAL but exact film length: How so?
    By azmoth in forum Newbie / General discussions
    Last Post: 5th Mar 2010, 11:42
  4. Replies: 34
    Last Post: 8th Feb 2010, 15:17
  5. Question regarding NTSC Film DVD
    By txporter in forum Video Conversion
    Last Post: 30th Nov 2009, 09:29
