VideoHelp.com Forum
Results 1 to 13 of 13
    Version: SVCD2DVD 2.1
    Build: 2.1.2474.30185
    Type: System.NullReferenceException
    Source: Interop.CodeLock
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at CodeLock._Secure.Authenticate(String pass)
    at AxCodeLock.AxSecure.Authenticate(String pass)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    My other copy worked fine i upgraded and i can't run it canyou Help Chrissy
  2. First suggestion - See if you have any dnb_xxxx.xml files in the SVCD2DVD folder, if so, delete them.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    I didn't have any i checked
  4. Does this occur at startup or somewhere in process? If it occurs in process, can you post your log file?
    Have you made any other changes to your system?
    Dwight
    - Herm Albright
    no changes and its on start up
  6. Probably not the case here, but do have all the updates for .Net 1 installed?
    Dwight
    - Herm Albright
  7. Member ChrissyBoy's Avatar
    Did you get any error messages when you installed?
    No Chrissy i tried it again and it started no error
  9. Member ChrissyBoy's Avatar
    So you are sorted?
    Strangest thing all is okay and working i forgot one thing i didn't burn my files i forgot to tell it to burn my project. Can you direct me to how to burn an existing project i have all the files just forgot what to do next
  11. Member ChrissyBoy's Avatar
    If you have a VIDEO_TS folder - use the ImgBurn Shell Ext.
    is there a quick tutuorial for this
    And thanks for all your help
  13. Member ChrissyBoy's Avatar
    Install ImgBurn
    Install the shell ext (from bottom of www.svcd2dvd.com)
    Then:
  1. Updating Driver
    By skorpinok in forum Computer
    Last Post: 27th Jun 2011, 22:03
  2. Updating X264vfw
    By hech54 in forum Video Conversion
    Last Post: 30th Jan 2011, 08:16
  3. Updating ffmpeg
    By whoisquilty in forum ffmpegX general discussion
    Last Post: 4th Apr 2010, 18:28
  4. updating windows xp
    By aruwin in forum Computer
    Last Post: 15th Oct 2008, 14:00
  5. updating drivers
    By romanstopme in forum Computer
    Last Post: 9th Oct 2008, 12:09
