VideoHelp.com Forum
    I have the K-Lite codec pack installed in my computer.
    do i need to install VobSub as well?
    THANX GUYS!
    No, you probably need to format your hard drive and reinstall Windows.
    jagabo, what? why?
    K-Lite is known to lead to all kinds of codec and other video related problems. Especially if you install/uninstall it a few times. Usually the only way of fixing the system is a fresh install of Windows.
    You're far better off installing the specific codecs you need. If you really want a "pack" try ffdshow. It's much cleaner. It includes subtitle filters too.
  5. Member Busman747's Avatar
    Check out this link GangstaRap http://forum.videohelp.com/viewtopic...689388#1689388 check out my problems and the solution at the end, this might explain jagabo's comment.
    Bilinear, Busman747, okay....
    that explains Bilinear comment...
    but!
    i'm using K-Lite codec pack over 2 years now and i'v never had
    any codecs problems!
    i also never suffered from lack of them!
    i dont know why it caused Busman747 problems with openin' AVI
    files...
    i know a lot of people using the K-Lite - and i'v never heard
    any complaints...
    maybe the results differ depending on which hardware or system
    configuration the codecs performed on...
    possibly?
  1. Virtualdub and K-Lite Codec Pack
    By EdoScario90 in forum Video Conversion
    Last Post: 9th Dec 2010, 15:26
  2. Fully reinstalling K-Lite codec pack
    By Xpenguin17 in forum Newbie / General discussions
    Last Post: 2nd Nov 2010, 20:09
  3. K lite codec pack
    By Pumkinhead in forum User guides
    Last Post: 26th Oct 2010, 13:12
  4. Disabling FFDshow (from K-lite codec pack)
    By mbcdc in forum Newbie / General discussions
    Last Post: 19th May 2008, 20:06
  5. Scraped the K-Lite Codec Pack now i'm in a crisis!
    By GangstaRap in forum Newbie / General discussions
    Last Post: 31st May 2007, 07:21
