I've found a bug on this program. At the first start, the program works fine. Since the second execution, the program not work properly. The bug is on the change of the scan folder. If we change the first folder of default ("C:\") replacing with another one, this may cause the malfunction of the next execution of this program.
The Bug is on the "Settings.ini" file. Changing the first scan folder, we have this file of settings.ini:
Code:ORIGINAL SETTINGS.INI [Settings] Overwrite=0 BuildScriptsIn=0 Splash=0 AvsFolder=C:\ MainFolder=C:\ Extenions=AVI|MPEG|MPG|MOV|DIVX|MKV|OGM|MP4|M1V|M2V ScriptExtensions=AVS|BAT|CMD|JOBS Template=C:\Programmi\ABatchScript\Templates\Default.avt MODIFIED SETTINGS.INI [Settings] Overwrite=0 BuildScriptsIn=0 Splash=0 AvsFolder=F:\Movies\AVS_Script MainFolder=F:\Movies\Videos Extenions=AVI|MPEG|MPG|MOV|DIVX|MKV|OGM|MP4|M1V|M2V ScriptExtensions=AVS|BAT|CMD|JOBS Template=C:\Programmi\ABatchScript\Templates\Trailer.avt
My solution![]()
I've make a CMD script (for Windows XP, for other SysOp it can be .bat file) as follow:
This script replace the new settings.ini with the original one. Make a copy of Settings.ini and modify it replacing the MainFolder string with "C:\" and set BuildScriptIn to zero (0).Code:@echo off copy /Y settings_original.ini Settings.ini START ABatchScript.exe exit
That's it!
Then execute the program with the CMD file, instead of the EXE file.
I wish this can help to someone.
kL0d3
Results 1 to 1 of 1
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 06:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 11:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 11:29
