I've been trying to get Riva FLV encoder 2.0 working but I've had no luck so far. 1.1 worked flawlessly but 2.0 won't even start properly. All I get is a dark square with a green outline in the top left corner of the Riva FLV Encoder window and I can't do anything else...any suggestions?
Thread: Riva FLV Encoder 2.0 Problems
I am having the same exact problem. The funny thing is, it only started to occur after I changed my motherboard. This could be due to many reasons, especially since the process required I reformat my HDD. I could be missing some codec or driver that the encoder requires. Has anyone seen this problem before? If so, any solutions?
"Now you know, and knowing's half the battle!"
KINDA HAVE THE SAME PROBLEM WITH CERTAIN FLV FILES..MOST OF WHICH WILL CONVERT CORRECTLY AND WITH NO PROBLEM..BUT WITH SOME I GET AN ERROR MESSAGE THAT I AM MISSING A CODEC..CAN SOME PLEASE STEER ME IN THE RIGHT DIRECTION..AS TO WHAT CODECS ARE NEEDED TO CONVERT TO AVI??? '
THANKING YOU IN ADVANCE
HONEYMARLEY
Hawkeye, you need to update your flash player. I usually need to install "install_flash_player v9.0.28.0.exe" followed by the debug version, "flashplayer_9_ax_debug.exe". Sometimes several times before it works. Installing either one by itself doesn't seem to work.
Yesterday I downloaded the world,
But it took up too much space so I had to purge it.
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
Riva encoder trouble
By Cyclope in forum Video ConversionReplies: 0Last Post: 27th Jun 2009, 12:09 -
Encoding for Riva FLV Encoder
By seven_deuce offsuit in forum Video ConversionReplies: 9Last Post: 11th Nov 2007, 03:47 -
Riva flv encoder and windows movie maker trouble.
By michigan2101 in forum Video ConversionReplies: 3Last Post: 29th Aug 2007, 22:23 -
Help with Riva Encoder, or Super, HELP!
By atomic22 in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 04:51
Statistics
Newest guides
Latest tool updates
New media comments
