hi
is there any program to check quality of burned disk under linux?
there is kprobe under windows but is there anything for linux?
thanks so much
http://dvdisaster.sourceforge.net/en/download.html
And some other info related to md5 hash under linux : http://www.g-loaded.eu/2006/10/07/ve...mage-on-linux/
Not 100% guaranteed , but could keep bad disc's down to a minimum .
well i thought about something different like kprobe for liteon drives or nerolinux cdspeed to check pi/po sektors and to scan quality of burned dvds but i am not sure if anything like this for linux does exist.....
so that program is not actually what i wanted....
any other ideas?
Theres been a few reports of users trying to run nero speed tools using wine under linux .
http://www.winehq.com/
From some reports , nero should not be far away with better support for linux .
there is no tool of its own to check PI/P0 scans under linux?
i am supprised....i thought every windows application has similar brother under linux...
so there is no reason to go with linux if those simple tools are missing for linux
If an application for PI/P0 scans has any bearing on your OS decision, I think you'd better get your priorities straight!
/Mats
http://qpxtool.sourceforge.net/about.html
What is QPxTool?
QPxTool is the linux way to get full control over your CD/DVD drives. It is the Open Source Solution which intends to give you access to all available Quality Checks (Q-Checks) on written and blank media, that are available for your drive. This will help you to find the right media and the optimized writing speed for your hardware, which will increase the chance for a long data lifetime.
Supported tests:
PIE / PIF / POF Scan
TA Scan
Jitter / Beta Scan
Transfer Rate Scan
C1, C2 and CU Scan
Extended CD Scan
Blank Media Quality Check
FE/TE Scan on blank media
FE/TE Scan on written media
Current linux support
debian packages.debian.org/unstable/otherosfs/qpxtool
gentoo forums.gentoo.org qpxtool-0.6.0.9.ebuild
SuSE Guru's RPM Site
drives supported by QPxTool:
list of supported ASUS drives (PIE and PIF tests):
ASUS DRW-0402P (oem Pioneer DVR-106)
ASUS DRW-0804P (oem Pioneer DVR-107)
ASUS DRW-1604P (oem Pioneer DVR-108)
ASUS DRW-1608P (oem Pioneer DVR-109)
ASUS DRW-1608P2 (oem Pioneer DVR-110)
ASUS DRW-1608P3 (oem Pioneer DVR-111)
list of supported BenQ drives (PIE, PIF tests):
BenQ DW-1620
BenQ DW-1640
BenQ DW-1650
list of supported LiteOn drives (PIE, PIF tests):
LiteOn LTR 52327S
LiteOn SOHW 811S
LiteOn SOHW 812S
LiteOn SOHW 832S
LiteOn SOHW 1653S
LiteOn SOHW 1673S
LiteOn SOHW 1693S
LiteOn SHW 1635S
LiteOn SH 16A7S
LiteOn SH-16A7S
LiteOn LH-18A1P
LiteOn LH-20A1P
list of supported NEC drives (PIE, PIF tests) :
NEC ND-3520, needs 1.UC+ (LD3520) or 3.04+ (Liggy)
NEC ND-3530
NEC ND-3540
NEC ND-3550
NEC ND-3570
NEC ND-3650
NEC ND-4550
NEC ND-4570
NEC ND-4650
list of supported Pioneer drives (PIE and PIF tests):
Pioneer DVR-106
Pioneer DVR-107
Pioneer DVR-108
Pioneer DVR-109
Pioneer DVR-110
Pioneer DVR-111
list of supported Plextor drives:
Plextor PX-130
Plextor Premium
Plextor PX-708A2
Plextor PX-712
Plextor PX-714
Plextor PX-716
Plextor PX-740 (untested)
Plextor PX-755 (needs firmware: 1.02, 1.04, 1.05, 1.06, 1.07)
Plextor PX-760 (needs firmware: 1.01, 1.03, 1.04, 1.05, 1.06)
list of supported Sony drives (PIE, PIF tests):
Sony DRU-700A (oem Lite-On SOHW-832S)
list of supported Teac drives (PIE, PIF tests):
Teac DV-W50D (oem Pioneer DVR-106D)
Teac DV-W58D (oem Pioneer DVR-107D)
Teac DV-W516D (oem Pioneer DVR-108D)
Teac DV-W58G (oem Lite-On SOHW-811S)
Teac DV-W58G-A (oem Lite-On SOHW-812S)
OEM models of listed drives and some other models
made by listed manufacturers should also work,
but you have to manualy select command set in some cases
All other drives should do the transfer rate test.
drives supported by PxControl:
Plextor Premium
Plextor PX-708A2
Plextor PX-712
Plextor PX-714
Plextor PX-716
older Plextor drives should also work
It'll get there , eventually .
good that is something i was talking about.....
Vid quality better in MPC (Windows), than MPlayer (Linux)...
By cwb in forum Software PlayingReplies: 3Last Post: 5th May 2010, 21:01 -
2 mpg stills: same encode options, vast quality difference ??? (linux)
By jungle5150 in forum Video ConversionReplies: 7Last Post: 26th Jul 2009, 10:14 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
Worse video quality on Linux than Windows with mencoder
By chiun in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:29 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
