hi i'm sam, i'm an indian, my parents got this dvd recorder from the US......its good i like it...but the problems are.....i also own a satellite dish...which is connect into my t.v to view television through satellite and also i own a Playstation 2.....i connected these both into the dvd-recorder....into IN1 and IN2.....but when i view it through the dvd-rec...the displayed is moved till down the screen..that means the top of the normall display is displayed in between my t.v...(we can see only half the display of the movie or whtever i'm seeing)....thats 1 problem..please help me configure that out....and the other problem is that when i connect my ps2...the same thing happenes.....BUT!! only the starting logo...(the blue screen and lights running around and showing "microsofts" things..and even the word "playstation 2" is like the half display).......but when the game starts it becomes alright....only the starting logo in the ps2 and the complete satellite dish is the problem in this dvd-rec
But when i connect them directly into the T.V it works Perfect......
NTSC is used in USA. PAL (I assume) in India. Incompatible units.
go to the setup on the dvd recorder go to tv type press on it change it to pal then see if it works then if it is on ntsc change it to pal see if it works if not then then thats not your problem
Panasonic DMR-ES35V
By RobJenk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Dec 2010, 13:42 -
use Panasonic DMR-ES35V with universal remote?
By kar120c in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Sep 2010, 14:14 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 15:27 -
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Jun 2009, 03:00
Statistics
Newest guides
Latest tool updates
New media comments
