VideoHelp.com Forum
    Hi guys
    Im kind of new here & having some problems, I am having a bit of a problem with subtitles in a movie, I made it from avi to Vob but when I put in subtitles in it using Srt2Sup, vobedit & Ifoedit. Unfprtenetly the subtitles come out roundabout in the middle of the screen & in green color, I would like to see them come out in the blank area below & in white color so if someone can help that would be great. thanks!!!
    you can change the position and color with dvdsubedit.
  3. Member mats.hogberg's Avatar
    Hi and welcome to the forum.
    Some rules of conduct:
    #1 Post in the correct forum.
    #2 Don't hijack threads. It's really easy to start your own.
    #3 Use this sites search function.
    You position the subtitle in srt2sup - check your settings there, specially PAL/NTSC
    At the end of the srt2sup run, IIRC you get a bunch of hex values. These should be entered in IfoEdit.
    Like mentioned, search, and look in the guides section.
    /Mats
    Thanks mates ill try it out & hope it works.
  1. subtitle position with aviaddxsubs
    By marioval in forum Subtitle
    Last Post: 27th Feb 2011, 19:15
  2. Subtitle Position
    By Abas-Avara in forum Subtitle
    Last Post: 25th Mar 2010, 15:09
  3. Replies: 2
    Last Post: 9th Nov 2009, 04:48
  4. DVDlab Pro subtitle color wrong after compile
    By nbarzgar in forum Subtitle
    Last Post: 9th Jun 2009, 09:29
  5. Subtitles : lower position / change color?
    By izzat in forum Subtitle
    Last Post: 25th Aug 2007, 10:21
