Just got Sony Handyman dvd108
Using DVD-RW DL. Recorded several files in 'video'format.
Ejected disc, inserted in pioneer 112d (brand new burner) - and windows explorer shows nothing on dvd. However, put it back in sony - files appear
Also put in in Standalone Phillips Divx player- shows 'root' folder- but no files.
I thought I can copy files straight from PC without using camcorder?
I installed sonys software- connected camcorder to PC. Found camcorder, found files, then copied them to PC.. But, I thought the mini DVD will play straight from media?
Yes, media was finalized. Please advise. Maybe its because im using Dual Layered DVD-RW media. Maybe I should just use Single sided RW media?
Cam doesnt even recognize 2nd side - unless I manually flip it over myself. I think cam only recognizes DL if this DVD+R DL media only.
dual sided and dual layer are two different types of disks
I bought these from ebay:
Double-side MINI DVD-RW disc can store up to 2.8GB.
So- I guess these are Double sided (not dual layered)..Meaning I must manually flip them over. Im OK with that...my real issue is..
OK. So, I still cant view the mpg files on my PC without going thru my camcorder. Is this normal? Just wanna be able to insert this disc into my pioneer or standalone and play. Heres link to discs I bought:
http://cgi.ebay.com/10-MINI-DVD-RW-M...QQcmdZViewItem
After further research, I found out Sony has made the files inaccessible unless you use their software. So I installed cd, ran 'import media files' app- and it found the files on the disc. So, I dont need to connect the cam, just run the app to find files.
Now, It makes 2 files for each video clip. .Modd and .mpeg. Can I delete the modd files? The mpegs play fine without em.
I know this post is pretty much old, but... well, I have this same camcorder Sony DCR-DVD108 and I can play the mpegs in Windows normally.
HOWEVER, I cannot importe this mpg in any software.... I don't know why.
Maybe I need a different coded?
MPEGs recorded with Sony DCR-DVD108 not compatible with any video software?
By MarcosJP in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 12th Oct 2009, 22:15 -
MPEG files from Sony DCR-SR80
By Rupert Bildge in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2007, 23:41 -
sony dcr-dvd 100
By Paulius in forum Camcorders (DV/HDV/AVCHD)Replies: 21Last Post: 2nd Sep 2004, 15:21 -
SONY DCR-TRV140E TO DVD
By sweetbee in forum Authoring (DVD)Replies: 10Last Post: 12th May 2004, 06:37 -
Sony DCR-PC105 or Sony DCR TRV80?
By Ignite in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 19th Feb 2004, 06:15
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
