VideoHelp.com Forum
    Im having a problem with fairuse at the moment and cant figure out what is wrong.
    It's ok all the way untill i hit next to start the encoding, the this error comes up " The DVD could not be converted, unable to create temp file"
    Does anybody have a hint for what might be the problem.
    Is the DVD encrypted? If you are trying to use a DVD that hasn't been cracked, FairUse Wizard can't use it.
    I Had the same problem I was using Vista
    I Use Admin mode and it worked for me
    No the DVD is not encrypted, and yes i am using Windows Vista, i have used fairuse many times before in Windows XP and no problem. atcakes... you run fairuse in adminstrator mode?
    I know fairuse can work on Vista because when i used it first time after installation it worked but only one time... and then no more. But if i uninstall fairuse and install it back again this error does not come, but the program stops either way in trancoding or in writing output file.
    atacakes do you have any more hint for me ? And did you install fairuse in adminstrator mode or just user, do you think that will matter?
    Thanks.
    Run with admin mode solve that problem : i dont know where fairuse write temp data... but that may not be the default windows temp... so that error...
    Where are theses temp data ?
  1. Fairuse Wizard
    By Simmons in forum Video Conversion
    Last Post: 17th Aug 2011, 18:34
  2. Fairuse Wizard problem (DVD to AVI)
    By Ygramul in forum Video Conversion
    Last Post: 31st Jul 2011, 17:33
  3. Fairuse wizard
    By pensioner in forum Newbie / General discussions
    Last Post: 26th May 2010, 12:37
  4. FairUse Wizard 2.9 muxing problem
    By herbapou in forum DVD Ripping
    Last Post: 17th Mar 2009, 11:21
  5. problem with fairuse wizard creating project
    By Wizard23 in forum Computer
    Last Post: 11th Jan 2008, 14:30
