I want to make a copy of a vcd and have the copy be able to play in a vcd player. Can I just copy all the files/folders (cdi, ext, mpegav, segment, vcd) from the vcd onto my harddrive and then burn all those files/folders onto a cd, as a data cd? Or do I need a program and have to do some authoring?
Thread: Making VCD Copy
Just do a disk copy of the cd. Your copy/cd burning software will treat it like any other CD.
Even a broken clock is right twice a day.
As Nitemare said, you need to do a disc copy of the VCD. Making a data CD with the same files and folders won't work as the file system for data CDs and VCDs is completely different.
Just as with an audio CD, you can't drag onto the desktop and back into your burning app. As the others said, you need to use your burning app to perform a disc copy operation. On a Mac, for example, you'd use Toast's Disc Copy option. On a PC, you can use, say, burnatonce (a free app that gets the job done).
Imgburn can also do it, and it's free and the author doesn't spam our forums
audiophile wrote:
Yes, IF: a) you know how to correctly sort the VCD files; b) burn the CD inCan I just copy all the files/folders (cdi, ext, mpegav, segment, vcd) from the vcd onto my harddrive and then burn all those files/folders onto a cd, as a data cd?
Mode 2. I myself do not know in which order the VCD/SVCD files must be recorded on
a CD; besides, Nero does not allow the user to sort files. mkisofs does let the user
choose the order in which the files will be recorded on the CD/DVD, but AFAIK
it cannot create Mode 2 disk images. mode2cdmaker is the toy I recommend
if you happen to feel like finding out how to play the game ^_^
MB increases when making copy of video fie.
By MaddogX in forum Newbie / General discussionsReplies: 16Last Post: 12th Oct 2011, 12:15 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
Making a copy with DVD santa
By 1234567 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 02:19 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:53
