I have a *HD* video 1920x1088@29.9700FPS.
It is encoded as H.264 AVC (originally a matrosoka file at 11GB)
My ultimate objective is to get the file playing on my PS3 with all the HD goodness of that 11GB MKV file!
I spent 8hrs last night encoding that file with Xvid4PSP.
My outputted file looks pretty good considering it's 4.3GB's but my problem is that the audio is about 45 seconds ahead of the video.
I came here to ask if:
1. Any program(s) that would let me tweak the audio-video interleaving?
2. Another program that does what my ultimate objective is.
I've spent the last 2 weeks of brainpower trying to get this video to play on my ps3. Since if i do it once, i can do it again and help others with the same problem. A time-saving method would be highly preferred.
Thread: A/V sync issues
If it is out by a constant amount, virtualdubmod can fix it easily without re-encoding. I have also used AVIDemux to do this, although other haven't had the same success. http://forum.videohelp.com/viewtopic.php?t=309224 has details
I only did 1 mkv file , and it was at a lower res 920*528
I ended up doing the same thing convert to DVd by 2 different paths
did you try mkvextract, it requires you install mkvmerge/mkvtoolsnix, then unzip mkvextracgui and place those files in the in the folder created bymkvtoolsnix
it took FOUR trys and resets before the program accepted the file, but it then did a very quick extraction of the source video to xvid avi with out altering or re-encoding, another run extracted the audio
avidemux will then mux the 2 tracks/streams back together as a standard avi-xvid codec with everything in sync and un-altered
in my case i then frame served the video stream to cce to get an elementry mpv file
because iwas converting to dvd
Weird Sync Issues
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Mar 2012, 11:56 -
Subtitle Sync Issues
By TheAlmighty in forum SubtitleReplies: 6Last Post: 2nd May 2010, 00:13 -
Sync Issues
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 27th Oct 2009, 00:41 -
tsMuxeRGUI and sync issues?
By BritishDragon in forum Authoring (Blu-ray)Replies: 7Last Post: 30th May 2009, 11:55 -
sync issues..what to do!
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2007, 07:57
Statistics
Newest guides
Latest tool updates
New media comments
