Hi, all,
Thanks in advance for helpful remarks.
I'm trying to convert an .avi file that measures 720x304 to a DVD using the DVD ffmpeg or DVD-MPEG2 encoder. When I use the options tab to add black bars in letterbox style, the bars are too tall, squishing the video. I thought I had found a solution by manually adding black bars that measure 60 pixels on the top and bottom. When I did that, the video is in perfect proportion, but it has black bars on the top, bottom, AND the sides, too! It looks like the movie is encased in a black box. I noticed someone with a similar issue at this unanswere post - http://forum.videohelp.com/viewtopic...&postorder=asc
Anyone got any ideas? Thanks very much!!!
Thread: DVD Doesn't Fill Screen
So you have a 2.35:1 AVI that you'll need to pad to make it 16:9. 720/(16/9)=405. (405-304)/2=50.5. Padding needs to be an even number, so 50px on top and bottom.
This letterbox field is only available for presets that use the ffmpeg engine, so use the DVD ffmpeg preset if you want to letterbox this way.
For DVD mpeg2enc, it's all a single checkbox. Just make sure you set Autosize to DVD 16:9.
AWESOME explanation. Thank you, Case. I have no doubt that it will work beautifully.
1280x1024 Resolution doesn't fill screen?
By mccoady in forum ComputerReplies: 20Last Post: 17th Oct 2008, 18:56 -
how to make dvd that does not fill up the screen!
By turbochargedRS in forum Authoring (DVD)Replies: 13Last Post: 20th Jun 2008, 23:37 -
Video height of 480 doesn't fill screen
By Grunberg in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 19:15 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
picture doesn't fill TV screen - let me back up and start over.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 21:48
Statistics
Newest guides
Latest tool updates
New media comments
