I hope this is the right forum ... I need to know if philips DVP630/02 supports playing subtitles. If it does, which kind?
Thank you!
Results 1 to 12 of 12
Thread: philips DVP630/02 subtitles
The 630 has the same support as the 642. It supports srt subititles in text (not image) format.
Google is your Friend
If the DVP-630 is like the DVP-642, you must select the subtitle first before selecting the Divx video. SRT in text format is your best choice. Supposedly the DVP-642 will support 1 or 2 other formats, but I was never able to make anything but SRT work.
unfortunately it doesn't work with the .srt subtitles. is it possible, that I have some 'wrong' settings?
Haven't made one in a while but...Originally Posted by Almica
Did you keep the name the same
ie...
1.srt
1.avi
If you mux the avi and srt then you can select the subtitle with the menu button. I prefer them that way since it's easy to turn them on and off.
Assuming you are activating them correctly, it's possible the srt file is corrupt or not in text format.
The movie and srt file should have the same name as suggested above. You must then highlight the srt file in the menu and press the subtitle button. You will then get a "subtitle selected" message (If you don't get the message or you only see the "hand", then the file is corrupt or the wrong format). Then highlight the movie and press play.Google is your Friend
I found out that if I edited a subtitle file in Unix/Linux, it didn't work. The Philips player expects the SRT file to have DOS CR-LF characters in it at the end of each line and Unix/Linux don't use those 2 characters to signify end of line. If you edit an SRT file on anything other than a Windows PC, you may have this problem. There are programs that can convert between DOS and Unix end of line sequences (unix2dos and dos2unix do this) and I used one of those programs and it fixed my problem.Originally Posted by Almica
what does in text format mean?
movie and subtitles have the same name.
when i select subtitles i only see 'hand'
i'll try with another movie but i'm afraid it'll be the same.
EDIT: it doesn't work with a different movie
Text format means the files are ASCII text files.
how do i check that?
You should be able to open the files using notepad, or any other text editor. If they are image format, a text editor can't read them.
I've also seen posts from other users that have recently purchased the 642 that can't get subtitles to work. So this could be an issue with the "new" 642.Google is your Friend
well i certanly can't get them to work. But the thing is I remember that they worked some time ago.
Philips DVP3560 and Subtitles
By Timex in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th May 2011, 16:29 -
Philips 5990/12 and asian subtitles
By saladbowl in forum DVD & Blu-ray PlayersReplies: 8Last Post: 9th Feb 2009, 10:21 -
New firmware v.0112 for Philips dvp630 (AKA dvp642 in usa)
By etab in forum DVD & Blu-ray PlayersReplies: 27Last Post: 14th Jan 2009, 09:58 -
Philips DVP5960 or DVP5980 and TXT subtitles
By Babers in forum DVD & Blu-ray PlayersReplies: 7Last Post: 10th Oct 2007, 12:46 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 14:06
