This one is new for me. I ripped a backup of Happy Feet on my PC and everything went good. After putting the original copy back in the DVD player, it stopped playing and gave me a copyright error. Has anyone run into this before?
Results 1 to 12 of 12
Thread: Copyright issues..
There's no way the orginal dvd can know it's been copied. Are you certain the disc you played and receved the error wasn't the back up?
You didn't use DVDXCOPY, did you???
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
i have had a similiar inciddent. my thought is that the dvd leaves a cookie on your HD. this happened with Casino Royale. i searched using windows explorer and found in that file an .exe extension. remember that sony had cd's that were encrypted and caused many problems. now before i get slammed as not having a clue this is only a thought, i have no technical evidence to support this, only that it has happened twice (Borat also)...and this is an very uneducated opinion.
You would have to install something or have something installed unbeknowst to you. Due to the slamming Sony took over the same thing I doubt any company will try that tactic again, unless you specifically installed something that said this will prevent copying of videos it's doubtful you have anything on your computer... of course I could be wrong but I certainly wouldn't want to be the executive that made that decision because if that's the case it will get found out.
Also note his problem is playing a already pressed DVD in a standalone DVD plyer which is competely different.
"There's no way the orginal dvd can know it's been copied"
i tend to agree on this statement. anyone else backup their copy of Happy Feet and experience this?
If your DVD player has "Autorun" enabled, then it is possible that something was "transfered" to your PC, be it a registry entry, a cookie, or whatever.
To prevent this from ever happening in the future, turn off this "feature".ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
I backed up "Happy Feet" with no problems... but I didn't try playing the original after I made my backup. FWIW, I used RipIt4Me.
Darryl
I'm assuming "pilot error" myself. I do know that Casino Royale has the non-DVD files that Sony is so famous for on the disc. Ripping it with RipIt4Me ignores these files and just rips the DVD stuff. If he tried to run the DVD from the original, it may have installed a "flag" on his system.Originally Posted by dphirschler
And, I'm also assuming that he is trying to play the DVD on the DVD player on his PC. If this is a standalone DVD player, then none of this makes sense (and none of what he said is even possible). I would also say that he definitely has "Autorun" enabled and is using it.ICBM target coordinates:
Happy Feet was not a problem. Casino Royale wouldn't even play in the old Apex - had to play it in the Panny DVD recorder instead.
Really weird about Casino Royale. It wouldn't even auto-run on my PC, the dvd drive didn't even see the dvd, and AnyDVD started playing up, messages saying 'Microsoft deteted error with AnyDVd and AnyDVD needs to shutdown' or somesuch. Then no other dvd's would recognised in my drive. I uninstalled and re-installed AnyDVd and other dvd's would play ok. The moment I stuck Casino Royale in the drive all hell broke lose again with AnyDVD giving errors and no other dvd's being recognised. What the hell did they do to Casino Royale (and its effect on Anydvd) ?????
Has Q been up to some dasterdly trick ?
As my uncle the car dealer always said(under his breath)..."It's the nut behind the wheel".Originally Posted by Fathead31
Copyright Question
By budwzr in forum EditingReplies: 10Last Post: 13th May 2011, 23:18 -
copyright infringement
By edong in forum Video StreamingReplies: 8Last Post: 4th Oct 2010, 02:34 -
where I get the copyright for a Song
By dieter wahr in forum Video StreamingReplies: 1Last Post: 14th Dec 2009, 20:46 -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 10:05 -
what's changed recently re Direct TV and copyright issues?
By sarainelkins in forum DVB / HDTVReplies: 3Last Post: 13th Jul 2008, 18:26
