my father is not able to access the internet at the moment and asked me to post this issue. i tried researching it, but i can't make heads or tails of any of this stuff. any help would be appreciated.
The problem I am having is the cam corder I bought in Gibraltar records
& plays with the PAL system. On my lap top computer I am using Adobe Premier
Pro to capture the video from the cam corder. I am using Nero Express to
convert it from PAL to NTSC & burn it to a DVD. I have tried capturing the
video in PAL & NTSC modes with Adobe Premier Pro. No matter how I try it the end
product is jerky (they call it stuttering in the book). It looks surrealistic.
I did not have this problem when I captured & recorded video from my old cam corder
which uses the NTSC system for recording & play back.
They talk about a trick called " 3:2 pulldown " to correct this , but the process
is not explained.
I know the PAL system records & plays at 25 fps & NTSC ( USA ) system records
& plays at 29.97 (30)fps.
Hi-
Open one of the vobs in a player that can both play vobs and pause and advance a frame at a time. I use Media Player Classic. Or you can use VDubMod. Scroll to a place with movement. Pause it and begin advancing a frame at a time. In MPC, I hit the right arrow of the keyboard. When doing that, do you see a whole lot of duplicate frames, on average one in every 6 frames being a dupe frame? If so, then that's the reason for the jerky/stuttering playback.
What to do? Well, for starters, don't use Nero Express. Make sure you capture as PAL 25fps. The best way then is to use an AviSynth script file to feed an MPEG-2 encoder (HCEnc is free and good). You resize for 720x480 and encode for 25fps. When done you run it through DGPulldown set for 25->29.97fps. Then it's ready to author with the audio, for NTSC DVD.
Or you can buy a DVD player that can play PAL DVDs.
Here's the FulciLives guide covering some of my points:
http://forum.videohelp.com/viewtopic.php?t=300144 -
Using PPro to convert PAL to NTSC will always result in choppy results.
It's because PPro uses a crude method to take 25 fps and map them into (approx) 30 fps. Inevitably, 1 out of 6 frames get junked.
To obtain quality conversion, you have to perform either frame blending or full-blown frame interpolation with motion compensation.
Adobe Premiere Pro How do I make the video Bigger?
By Devilsadvocate in forum EditingReplies: 5Last Post: 25th Mar 2012, 15:44 -
Adobe Premiere Pro - video proxy tutorial???
By rallymax in forum EditingReplies: 5Last Post: 28th Aug 2009, 00:46 -
How to change NTSC to PAL in adobe premiere elements 7
By jarko in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 20:28 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 14:16 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06
