VideoHelp.com Forum
Results 1 to 10 of 10
    I recently bought a used Hi8 Camera with paranormal nightvision mode and everything seem to be fine except when I tried it... the salesman sent me 3 8mm tapes which recorded fairly poor due to dirty heads so I cleaned the video heads first blowing air to it then I use alcohol and chamois pads and a bit of cotton swaps for the rest... but then I decided I should use try a hi8 tape and tried it... the quality was horrible with distorted lines all over... I tried the other 8mm tape I just removed and it played better and record just fine... so I thought may it needed to dry. Once again I tried the hi8 tape and nothing, tried a new hi8 tape and nothing... tried the 8mm and it works... so my question is.... why my camera doesn't like the preferred hi8 mode?
  2. Member classfour's Avatar
    Heads? or is the camera only 8mm
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Camera is CCD-TRV108 and there is emblem video Hi8 written on the plastic... google it is a hi8 cámera. The camera is excellent but it has this problem I would like to know how to solve... I cleaned the heads... what can it be wrong?
  4. Member edDV's Avatar
    It should be working. Hi8 tapes record with different FM modulation for wider frequency response but uses the same heads. Try a professional cleaning and evaluation at a camcorder repair shop.
    same heads but perhaps different speed? or something... my 8mm tapes record and play fine.
  6. Member edDV's Avatar
    Same speed, different FM modulation (deviation).
    http://www.videointerchange.com/formatsupport.htm#Hi8
    I read something odd... I heard the sensor could be bad on my camera not detecting is a hi8 tape?
  8. [quote="CCEncoderI read something odd... I heard the sensor could be bad on my camera not detecting is a hi8 tape?[/quote]
    If that were true, I would expect the camcorder to default to 8mm.
    John Miller
    enosoft - high performance tools for music and video
    Home of the Enosoft DV Processor - Free for personal use!
    [quote=JohnnyMalaria]
    Originally Posted by "CCEncoderI read something odd... I heard the sensor could be bad on my camera not detecting is a hi8 tape?[/quote
    I also heard it can be a circuitry issue... is this reparable or replaceable?
  10. Originally Posted by CCEncoder
    Repair? Unlikely.
    Replace? Yes - but to have Sony do it will probably cost more than you spent on the cam. You could get an identical model of eBay and swap the offending circuit board. But it will be something of a crapshoot and you'd need a service manual (ideally!)
  1. Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
    By Optical in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 4th Nov 2011, 05:33
  2. Replies: 18
    Last Post: 25th Jan 2011, 22:00
  3. I have about 60 Hi8 and regular 8mm camcorder tapes that I can't get toplay
    By Chris McDowell in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 7th Jun 2010, 18:12
  4. Sony Hi8 has been defective but want to play the Hi8 tape
    By coody in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd May 2009, 22:06
  5. Hi8 vcr, better playback than a Hi8 camcorder?
    By Knightmessenger in forum Capturing
    Last Post: 22nd Dec 2007, 01:11
