Where would i go to find out what i need and whats best to buy, as well as how to set up...holla back asap
Results 1 to 12 of 12
Thread: Setting up a server at home?
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
What do you want it to serve and to what and/or where?
Buy My Books
multimedia files, to other computers in the house
I highly endorse this as a learning exercise. Many go to college to learn the art and make a good living at it.
http://www.kiva.org/about
Then just setup Shared Network Folders for everyone on the Network....
but that still requires a comp to be on constantly, i would like a server just dedicated to serving files...even if its a comp...how would i start to set one up??????????
I have a old P3 650 MHz with 512MB ram and a 120 GB hard drive running Win2000 Pro and I can play any of the videos on it on all of the hardwired computers on my network that are capable of playing the files on their own.
Edit: As suggested above, I just map drives to it and play the files directly."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
is there anyspecial server type software set up on their to administer the rest of the comps on the network??????
No, it's not designed to administer the network. It just holds the files and allows access. If you want to do more than that then I modify my original question, What all do you want it to be able to do?Originally Posted by SIRCOOKS"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
You want to stream multimedia files then look here:
http://www.videolan.org/vlc/streaming.html
There are HDD enclosures with network connections. Seems like a simple way to have a shared file storage.
http://www.netgear.com/Products/Stor...ome+Networking
/Mats
If all you want is file storage and access, you can use any OS (Win 2000 or XP recommended though) and just share the root folder (or drive) where the files reside. The simplest set up would be to give the Everyone user Full Control. Then map a drive on each of the computers you want to access the content from using ComputerName>\<sharename>.
If you want to stream content across your own LAN, then I would look at either VLC or Windows Media Encoder.If in doubt, Google it.
Home server/Networked HDD
By OverrRyde in forum Newbie / General discussionsReplies: 16Last Post: 14th Jun 2011, 20:08 -
Rip to central server on my home network and stream to TV or computer
By RJC5XTC in forum DVD RippingReplies: 1Last Post: 13th Dec 2010, 20:03 -
home server port forwarding
By gooberguy in forum ComputerReplies: 6Last Post: 17th Feb 2010, 12:54 -
Need advice on setting up a home media server
By jamietallman in forum Video StreamingReplies: 2Last Post: 7th Jan 2009, 00:25 -
Home Media Server
By muehleis in forum DVD RippingReplies: 2Last Post: 14th Aug 2008, 14:53
