Hi guys, not sure if this question been covered before, but is it possible to add subtitle into rmvb file? or do i need coversion first? =/
Thread: Possible add subs to rmvb file?
I found this at the Afterdawn Forum: http://forums.afterdawn.com/thread_view.cfm/250986 from manicalic:
It sounds like it should work. I would try .srt subtitle format.Three separate ways to have subs in .rm(vb) files:
NOTE: all require Real Alternative
IMPORTANT: before installing RealAlt you MUST uninstall Real Player (will not work anyway)
NOTE2: Subtitles file has name exact as movie, extension is appropriate for subtitles format.
1. open file in player supporting subs (Bestplayer etc.)
2. Media Player Classic:
Options > Playback > Real Media Video > (choose) DirectX 7/9
Can now (auto)load subtitles
3. Installed DirectVobSub: just change extension from .rm(vb) to .avi (not convert, just change filename), DVobSub will load subtitles automatically.
3rd way is the only that works in Windows Media Player.
There is a 3rd party tool that allows you to mux subs into a rmvb file. Then you definitely need Gabest's splitter for playback though. Then again mplayer may work. Officially I think subs are supposed to be loaded via SMIL for rm/rmvb files. Should work fine in Real Player that way.
Add hardcoded subs in a mkv file
By joost1 in forum SubtitleReplies: 9Last Post: 2nd Nov 2010, 16:54 -
simplest way to add subtitles to rmvb file
By looloo in forum SubtitleReplies: 4Last Post: 24th Jan 2010, 20:43 -
I can't add subs to a DivX file I have for some reason...
By darkzero297 in forum SubtitleReplies: 1Last Post: 4th Jul 2007, 18:41 -
Merging a video file with subs and converting it to .rmvb at the same time?
By whatever911 in forum SubtitleReplies: 3Last Post: 27th Jun 2007, 10:08 -
how do you get rid of hard subs? especially rmvb ones?
By chaejunghoon in forum SubtitleReplies: 1Last Post: 12th Jun 2007, 20:24
Statistics
Newest guides
Latest tool updates
New media comments
