Hi there,
I've used ISOBuster to recover some video from my Canon Camcorder's mini DVD disc.
I have two VOB files which play fine using something like WinDVD or one of those programs that comes bundled with my Toshiba laptop that allows you to play DVDs.
But I want to author a DVD using this video and my DVD authoring program does not like VOBs so I want to convert it to MPG.
Now when I vob2mpg, it doesn't process the files, it just says 0 files processed, etc. Is there a specific naming convention I need to use for the VOB Files? I even tried putting the VOBs into the VIDEO_TS folder but that still didn't work.
What am I missing?
thanks,
Keith
I do not know what is your authoring software, but try Mpeg Video Wizard DVD it will import VOBs, let you build menu and export to DVD file for burning
http://www.womble.com/download/index.html
"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
Just add the VOB files in Mpg2cut2 and save them as a single MPG file.
kbailie, I had the same problem with VOB2MPEG and it turned out the program didn't want to save to the same drive as the source VOBS were on. Maybe a left over from normally reading from a DVD drive and saving to a disk drive. When I chose a different drive to save to, works perfect.
All that was probably spelled out in the information for the program, but I never read manuals.
Of course if you don't have two drives on your system, might be a problem. But then again, you may be able to save to a virtual drive like Daemon Tools sets up.
Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
By buzzworm in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2012, 16:22 -
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 16:47 -
I can't finish register process(VOB2MPG pro)
By xwestwood in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 8th May 2010, 12:35 -
VOB2MPG PRO Runs But Doesn't Process
By majones in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 23rd Dec 2009, 04:11 -
VOB2MPG won't start up
By lesonja in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 2nd Jan 2008, 12:24
