VideoHelp.com Forum
Results 1 to 17 of 17
    hi everyone...i have a show that i've captured via my firewire from my digital stb to my computer. now when i load it in dvd2avi or dgdecode it says that it's 29.97/interlaced. so i converted it to dvd format using this script...
    LoadPlugin("C:\DVD Tools\AviSynth 2.5\plugins\DirectShowSource.dll")
    MPEG2Source("filename.d2v")
    LanczosResize(720,480)
    ConvertToYUY2()
    and loaded that script into CCE SP. then under advanced video i ticked upper field first/close all gops. and in quality i set it to quantizer=16, intra block=10, block scanning=alternate. i then set my number of passes, bitrate etc.
    now the problem is...i converted/authored/burned it and it looks "ok" on my tv, except when there's a scene change it looks kinda blurry/flashy for a second and i can seem to see the interlacing. is this normal or am i doing something wrong? the source file does not look like this...any help would be great...thanks very much.
  2. Hi-
    There's quite a bit that's puzzling here. You should be using an up-to-date DGMPGDec package which contains the DGIndex to make the D2V project file, and the DGdecode.dll you'll need to decode the video. So, you script should read:
    LoadPlugin("C:\Path\To\DGDecode.dll")
    MPEG2Source("C:\Path\To\Video.d2v")
    Read this (also included with DGMPGDec):
    http://neuron2.net/dgmpgdec/QuickStart.html
    Next, if the source is already 720x480, then you don't need the LanczosResize line. If it's not already 720x480 (why isn't it?), that's not how you resize interlaced video, and could perhaps be responsible for your problem.
    That will be correct if it's really TFF. Is it?
    If the video is interlaced, your last line should be:
    ConvertToYUY2(Interlaced=True)
    On what are you seeing interlacing, a standard CRT interlaced TV set, or some kind of an HDTV? And if it's a movie or something else shot on film, it can probably benefit from an IVTC. If you could upload a small piece of the source, a 5-10 second section with movement, that would help us to diagnose the problem, and give advice on how to treat it.
    when i capture through firewire from my stb, the resolution is only 528x480...don't ask me why but other people report the same resolution when recording. also, i don't know how to check if it's top field first. so i guess i need to figure out the field order and also the proper way to resize to 720x480.
    thank you for your quick reply, btw.
    here is a sample...sorry, sendspace is the only place i could think to upload it to...
    http://www.sendspace.com/file/94ltbu
    It's essentially progressive.
    I'd use this.
    LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\dgdecode.dll")
    mpeg2Source("sample.d2v")
    telecide(order=1)
    lanczosresize(720,480)
    converttoyuy2()
    (for telecide you need the decomb filter http://neuron2.net/decomb/decombnew.html )
    To determine field order use:
    assumetff().separatefields()
    serve the script into VirtualDub and find an area with motion. Single step forward, if the motion always progresses it's tff. Substitute the above with assumebff, and double check.
    To correctly resize interlaced material:
    separatefields()
    lanczosresize(720,240)
    weave()
    converttoyuy2(interlaced=true)
    ok, so i used your methods (thank you very much btw) and found out that it was top field first. now in making my final script, should it look like this...
    LoadPlugin("C:\Program Files\DVD Tools\AviSynth 2.5\plugins\dgdecode.dll")
    mpeg2Source("dexter.d2v")
    telecide(order=1)
    separatefields()
    weave()
    i would like to resize it to 720x480, that is why i included everything you wrote. thanks again.
    no.
    apologies i got it wrong
    use:
    separatefields()
    weave()
    And this would make it progressive.
    fielddeniterlace()
    converttoyuy2()
    as a quick fix that is.
    to return to true progressive you'd use this:
    telecide(order=1)
    selectrangeevery(5,4)
    converttoyuy2()
    as it's pulldowned progressive that ended up being converted to interlaced 29.97.
    for the sample though as frame 0 doesn't start the 3/2 sequence to see the result I used:
    telecide(order=1)
    trim(3,312)
    I assume the video would start the 3/2 sequence at frame 0 though.
    i'm not experienced enough to know.
    i suck at this
    fielddeniterlace()
    converttoyuy2()
    shouldn't that be:
    because i checked it with media player and it was squished to 720x240
    yeah...
    copy paste, and tired eyes
    I think I've got it now.
    but I'm sure someone else will better help you soon
  9. Member Soopafresh's Avatar
    I'll throw one into the mix Requires TIVTC.dll
    ###Start
    function FieldMatch(clip c) {
    global pp = c.DuplicateFrame(0)
    global cc = c
    global nn = c.DeleteFrame(0)
    p2 = pp.SeparateFields()
    c2 = cc.SeparateFields()
    n2 = nn.SeparateFields()
    global pc = Interleave(p2.SelectEven(), c2.SelectOdd()).Weave()
    global cp = Interleave(c2.SelectEven(), p2.SelectOdd()).Weave()
    global cn = Interleave(c2.SelectEven(), n2.SelectOdd()).Weave()
    global nc = Interleave(n2.SelectEven(), c2.SelectOdd()).Weave()
    return ScriptClip(cc, \
    "!cc.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? cc : " + \
    "!nn.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? nn : " + \
    "!cn.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? cn : " + \
    "!nc.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? nc : " + \
    "!pp.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? pp : " + \
    "!cp.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? cp : " + \
    "!pc.IsCombedTIVTC(cthresh=12, MI=80, blockx=16, blocky=32) ? pc : cc")
    Mpeg2Source("your.d2v",cpu=4) #source needs a bit of deblocking
    ConverttoYV12() #or not if you can get away with it.
    Fieldmatch()
    Tfm()
    Tdecimate()
    crop(0,56,-0,-64)
    # AddBorders()
    ###End
    Resulting in:
    clip.avi
    A small note on this script:
    separatefields()
    weave()
    It could be reduced to:
    Since LanczosResize() won't be changing the vertical size it won't mingle the two fields.
    thanks for all the help guys...i'm gonna give a couple a try and i'll let you know the results. cheers!
  12. What's the matter with a simple:
    LoadPlugin("C:\Path\To\TIVTC.dll")
    MPEG2Source("C:\Path\To\Sample.d2v")
    TFM().TDecimate()
    ConvertToYUY2()
    or, if using Decomb:
    LoadPlugin("C:\Path\To\Decomb.dll")#use whatever version name you have
    AssumeTFF()#if that's what it is
    Telecide(Guide=1).Decimate()
    ConvertToYUY2()
    With newer versions of Decomb, you no longer set the field order within Telecide, but it should be set with an AssumeTFF/BFF. A Telecide without Decimate keeps it at 29.97fps, with a duplicate frame in every 5 frames. Under no circumstances should it just be deinterlaced.
    TFM().TDecimate()
    ConvertToYUY2()
    ConvertToYUY2()
    I think I'm gonna give your 1st one a try and see what happens...any idea where i can find the TIVTC.dll plugin? Thanks.
    nevermind...found the latest version.
  14. Good. Remember though, you'll be encoding for 4:3 23.976fps progressive. Before authoring you'll have to have applied Pulldown. You can do this in CCE while encoding, or afterwards using something like DGPulldown. Applying 3:2 (or 2:3) Pulldown has your 23.976fps video output 29.97fps as required for NTSC DVDs. Make sure and test out your script in VDub(Mod) before sending to CCE. Good luck.
    thanks for the info, the one thing i do know about is pulldown and stuff! lol
    just one more question...can/should this method be used for all my captures off of tv that are in 4:3 format? and for 16:9 do I just add a crop to the script or are there other steps involved?
  16. thanks for the info, the one thing i do know about is pulldown and stuff! lol
    Good, but a lot of people don't, and then wonder why they can't author their 23.976fps video.
    Only the ones sourced from film. Open that sample in VDubMod and advance a frame at a time. Notice how you have 3 progressive frames followed by 2 interlaced frames in every 5 frame sequence. 3-2-3-2. That's the sign of it having been shot on film and telecined. An IVTC removes the telecine and returns it to its original progressive 23.976fps. You can do this for most movies and a lot of TV shows. If every frame is interlaced, you can't IVTC. Leave it alone and encode for interlaced 29.97fps. You might check around edits, like at the commercials, and make sure that you don't have problems like stray interlacing or some sort of jerkiness. You shouldn't, though.
    Crop and resize. If interlaced, you have to be careful. I do it like this:
    LeakKernelBob(Order=1)#if TFF
    #Crop, resize and filter here
    SeparateFields()
    SelectEvery(4,0,3)#if TFF
    Weave()
    And encode for TFF. You'll have to Load the LeakKernelDeint filter.
    awesome...thank you very much for all your help....everyone!!!
  1. AviSynth Script Problem
    By Eva-Unit01 in forum Editing
    Last Post: 29th Dec 2009, 12:00
  2. Mr. Bean Animated series avisynth de-interlacing issues
    By rickydavao in forum DVD Ripping
    Last Post: 2nd Nov 2009, 14:40
  3. Still images from AviSynth script problem
    By Leo48 in forum Newbie / General discussions
    Last Post: 27th May 2008, 15:54
  4. Avisynth script problem (aac to wav conversion)
    By greggery in forum Video Conversion
    Last Post: 22nd Nov 2007, 11:59
  5. avisynth script
    By magenta2007 in forum SVCD2DVD & VOB2MPG
    Last Post: 25th Sep 2007, 11:29
