VideoHelp.com Forum
    Hello I am trying to convert a file in mpeg stream clip. the original HD file is about 4.6gb for the hour show. when i place it in mpeg streamclip and convert to .mov or .avi the file ends up over 15gb. What should my settings be? how can i get it down to about 1-1.5gb per hour. Thanks so much for the help.
    ~Srahusson
    Use a compression like h264 and set the data rate and you will see the output file size,
    Thanks. I tried that but do you know why it took so long? it took several hours to complete for the hour show. Is that normal? Also will those settings maintain HD like quality? i want to compress it but maintain HD resolution or near Hd res. thanks for your help.
    ~Srahusson
    One last question. Is there a way to keep 5.1 surround? if so what settings do i need for that?
  1. Why Can't I convert the whole file in mpeg streamclip?
    By alphonsecpone in forum Video Conversion
    Last Post: 5th Mar 2011, 09:24
  2. Help !!Convert a trp file with Mpeg streamclip
    By caliman in forum Video Conversion
    Last Post: 21st Oct 2010, 11:55
  3. AVI settings in Mpeg Streamclip
    By roonyards in forum Mac
    Last Post: 14th Dec 2009, 11:56
  4. How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
    By MAdNEZ in forum Newbie / General discussions
    Last Post: 4th Aug 2009, 07:30
  5. MPEG Streamclip Settings for Editing
    By RowlandBTV in forum Mac
    Last Post: 14th May 2009, 14:29
