Results 1 to 13 of 13
  1. (I noticed I originally posted this in the wrong forum, so after deleting the original post, I'm reposting my query here)
    I've run into this problem with a few versions of ffmpegx and given up on them before, but I just thought I'd ask here for the record:
    Occasionally (and less often with 0.0.9x) when I'm converting .AVI or .VOB files to something else (it doesn't seem to matter which format), ffmpegx cops out and creates a file that is 0kb immediately at the start of encoding. Is there a fix for this? Am I just missing something that would fix this problem?
    I don't think it would be my setup, as this has happened with different versions of the app on different computers (both intel and ppc).
    Thanks for any help problem-solving!
    Thanks.
  2. Explorer Case's Avatar
    The Log may hold clues to why a conversion failed. You may access the Log by clicking the blue "i" in the ffmpegX Progress window.
    Based on any error found in there, fellow users may be able to suggest a fix.
  3. Ah, ok - I was unaware of this function. I'll try it again and post what I come up with. Thanks a lot for your help!
    Thanks.
  4. Member fernblatt's Avatar
    I have a similar problem, but the progress window indicates it's been converted. Now I know where to look. With me it happens nearly *every* time I convert to a .mov file.
  5. Explorer Case's Avatar
    But what does the Log ("Process Information" window) say?
    I have the same problem, and what it says is the following:
    "Encoding started on Tue Oct 23 16:20:43 CEST 2007
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/danieldaboczy/Desktop/Fargfabriken.tv/Playing the Building.mov':
    Duration: 00:09:47.3, start: 0.000000, bitrate: 24422 kb/s
    Stream #0.0(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Stream #0.1(eng), 25.00 fps(r): Video: h264, yuv420p, 720x576
    Codec type mismatch for mapping #0.0 -> #0.0"
    The thing is that I could encode without probelm before....And now it just doesn't work.
    please help me
  7. Explorer Case's Avatar
    Your source file has the audio stream (#0.0) mapped before the video stream (#0.1). This is reverse from what the ffmpeg engine expects. You may fix this "Codec type mismatch for mapping"-error by indicating that the streams are reversed. To do so, check the "Invert mapping" checkbox in the audio tab.
    Thanks for the answer - totally fixed my problem.
    I also have creating zeroK file problem when trying to convert mov file to flv.
    Here is the log. Any suggestion will be appreceiated.
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
    Tue Jul 28 18:20:12 EDT 2009
    that stream 1 comes from film source: 2997.00 (2997/1) -> 29.97 (30000/1001)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/LaCie160-2/STABIAE/DemoOUTPUT/Stabiae_Demo99.mov':
    Duration: 00:10:58.3, start: 0.000000, bitrate: 1261 kb/s
    Stream #0.0(eng): Audio: aac, 48000 Hz, stereo
    Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 640x480
  10. VH Wanderer Ai Haibara's Avatar
    Have you tried the solution Case mentioned, above?
    I have a similar problem when i try to convert an avi file (+subs in .srt format) to dvdffmpeg preset: the progress window indicates it's been converted and the only file created is a .mpv file with okb.
    here's my log:
    Encoding started on Sun Dec 27 17:32:43 BRST 2009
    movtoy4m
    Copyright 2002-2006 Johan Lindström
    All rights reserved..
    Input #0, yuv4mpegpipe, from 'pipe:':
    Duration: N/A, bitrate: N/A
    Stream #0.0: Video: rawvideo, yuv420p, 720x480, 23.98 fps
    Output #0, rawvideo, to '/Users/renato/Desktop/VD_s1_e1.avi.ff.mpv':
    Stream #0.0: Video: mpeg2video, 720x480, 23.98 fps, q=2-20, 4000 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    [mpeg2video @ 0x381324]qpel not supported by codec
    Error while opening codec for stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
  12. Explorer Case's Avatar
    Originally Posted by roover
    avi + srt to dvd ffmpeg
    Try turning off Quarter pixel ME (qpel) in the Options tab. Qpel is not supported in MPEG-2 video.
    dvd ffmpeg preset
    Output ... 23.98 fps
    A DVD with a framerate of 23.976 fps (aka NTSC FILM) should have a so-called "3:2 pulldown" flag set. The DVD ffmpeg preset does not automatically add this pulldown. You would have to manually add the pulldown to the .mpv video stream before muxing and authoring, using the Pull tool in ffmpegX. Possible, but not so easy.
    Perhaps it is easier to use the DVD mpeg2enc preset, which does allow adding a 3:2 pulldown during conversion, by checking "Set 3:2" in the Options tab.
    Yeah! the conversion its running ok now!
    Thanks Case!
  1. Movie Maker files not encoding in ConvertxtoDVD properly
    By KJShearer in forum Authoring (DVD)
    Last Post: 27th Aug 2009, 19:23
  2. Getting 0KB files when trying to convert Real Video to other formats
    By j1201 in forum ffmpegX general discussion
    Last Post: 13th May 2007, 05:34
  3. does ffmpegx create invisible cache files when encoding??
    By trevytrev in forum ffmpegX general discussion
    Last Post: 13th Jan 2006, 18:28
  4. Nero creates DVD files, Womble creates mpeg2 files
    By apocalypse in forum Video Conversion
    Last Post: 24th Mar 2005, 21:49
  5. ffmpegX 0.09b still creates m2v files instead of _TS files
    By calu in forum ffmpegX general discussion
    Last Post: 4th Apr 2004, 10:09
About   Advertise   Forum   RSS Feeds   Statistics   Tools
