Results 1 to 30 of 31
    Mar 2007
    Philippines
    I have a Sony DVD RW DRU-810A and I'm using Adobe Encore to make my dvd's. I have a problem with the write speed of my writer that usually just gives me 2x,4x,6x and 8x. When I burn it at 2x my dvd's jump or skip. Is there a way I can force the writer to burn my dvd's at 1x? Thanks
  2. Sony says the slowest rated speed for that model on DVD is 2.4x - so unfortunately the answer is no. Can you be more specific about the problem? What media have you tried and on what playback devices are you seeing this problem?
    Mar 2007
    Philippines
    I use TDK dvd disc. My clients brought the disc to the US and the video was not playing as it should. When they brought it home to Manila and tried it on their Philips player it also did the same thing. Should I change my media? Or should I change softwares? Thanks
  4. Does the video skip when played on a PC?
    If so then it could be an encoding problem,if not then it's probably a compatibility issue.
    Use Nero CD-DVD Speed to check the DVD for errors.
    See www.nomorecoasters.com and get better media.
    Mar 2007
    Philippines
    No the DVDs can be played on a PC smoothly. I will try the Nero CD-DVD speed.
  7. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    They should clean their player.
  8. Originally Posted by [_chef_
    It's highly unlikely that all of the players need cleaning when mommyc said it plays fine on his/her PC,it's probably the disc.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If Adobe Encore has a built in burner....stop using it. Export the finished product to your hard drive then burn with a more reliable burning tool like ImgBurn (free) or Prassi Ones (30 day trial and very inexpensive)....and get better discs. TDK stuff was garbage way back when they made audio cassettes too....nothing has changed.
  10. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Was just a suggestion...you never know.
    But probably its really best not to use the burn engine in Adobe.
  11. Are you encoding your videos to NTSC for your US clients ???
    PC don't care about pal/ntsc for playing
  12. cd090580 got the golden ring.
  13. Originally Posted by cd090580
    Philippines uses NTSC also,if you play a PAL DVD on a NTSC tv you will see horizontal lines and the picture will be B&W.
    If you are able to change to 1X, it is likely to make your problem even worse. Most DVD media doesn't like to be recorded at 1X. I don't mean to be offensive but your burner was marginal when new and now that it has some miles on it, it is probably on its decline. These days you can get a good drive for less that $40 if you shop around a bit. One good choice is the Pioneer 111 or 112. I also encourage you to take Lord Smurf's advice and use good media.
  15. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    As those of us who own DVD recorders know well, most DVD media will tolerate burning at 1X just fine. Unfortunately many DVDwriters do a crappy job at 1x.
    Manufacturer's recommended media lists for recorders show a broad spectrum of media from many countries and factories. And all are recording in realtime.
    Mar 2007
    Philippines
    Thanks for all the replies. Yes I am encode at NTSC for US clients. I also have a laptop which I use to burn my dvd's at 1x. It's a matshita. I still use adobe encore and burn at 1x with the same media and it plays just fine. I concluded at I should always burn at 1x. I was already thinking of buying another dvd writer. Thanks for the advice. How fast do you guys burn your dvd's and what media to you use? I have another DVD writer that's a hi-val by benq, i think. is that an okay burner?
  17. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    BenQ drives are notoriously +R Media friendly....and my favorite media(along with millions of others) is Taiyo Yuden -R media:
    http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1736-1...ode=TAIYOYUDEN
    I've never tried Taiyo Yuden +R media. I'd imagine it is the same outstanding quality as their -R stuff.....but I'd venture to guess that their -R stuff outsells their +R stuff by at least two to one?
    High speed burning is NOT important...but it's also well known fact that burning slower than the rated speed of the disc can also cause problems....especially with today's discs.
  18. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    As heck54 mentioned use IMGBURN to burn your dvd discs which you can set it to burn at 1x spd. I have never burned at 1x spd. BTW your SONY 810 drive is a rebadged BENQ 1640 drive. You could crossflash your drive to the official BENQ 1640 firmware if you wanted to. The Hival drive you have could also be a rebadged BENQ 1640 or 1650.
  19. Originally Posted by mommyc
    I always burn at 4x or 2x on cheap noname dvd. All my disks are perfectly readable without any problems.
  20. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    MatSHITas are crap burners. You can only record the DVDs at 1x because these burners support that less discs and MIDs.
    Crossflash the Sony to BENQ or get a decent burner and decent media.
    *** Now that you have read me, do some other things. ***
    Mar 2007
    Philippines
    How do i cross flash my sony dvdwriter with a benq driver?
  22. Member oldandinthe way's Avatar
    Mar 2006
    You should be able to find the firmware info on the LiteOn/SONY forum at CD freaks
    http://club.cdfreaks.com/forumdisplay.php?f=44
    Looking here will be faster than waiting for someone who knows the exact details.
  23. Member
    Mar 2007
    Philippines
    thanks!
  24. My new Burner LG-H22N will burn automatically at 16x if the media allows.
    I have found however that many dvd players will not play media burnt at 16x, is there a way of setting the dvd burner to max at 8x, or does it have to be done every time I burn a disc.
    I also use LG 4163B and 4160.
    Many thanks
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  25. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Many thanks
    Nope, YOU decide and tell the software how fast it should burn via the burning app.
  26. Member
    Apr 2007
    Philippines
    Setting the burnspeed to 1x (or any available speed) in imgburn or in any burning software for that matter is useless if your dvdburner doesn't support it. You can check it by burning at 1x or 2x on a burner that doesn't support burning at those speeds for dvd-r (1x and 2x is only supported in dvd-rws in my burner anyway). Imgburn will display the speed you set it but in the actual write speed it defaults to the minimun the burner could burn in my case 4x.
    I guess you could download firmware that let's you "downgrade" your burner. In Liteon you could try changing the burning profile of your dvd disk to something similar to a dvdrw to so that your burner would allow burning at 1x or 2x. At least in theory. I forgot the software but it is in clubcdphreaks and it is what they suggest when your burner has problems with burning new incompatible dvdmedia.
  27. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Todays burners cannot burn DVD-R at 1x and it would not make a sense either..........
  28. Member
    Jan 2007
    Republic of Texas
    Counterfiet DVD discs are common in the Philippines. Did you get your TDK discs at a reliable place, like SM or a Mall of Asia store? Even if the TDKs are genuine, you might want to try something different, as was suggested in previous posts.
  29. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Lmao! this thread is so old and someone post to it when the OP had never replied to any of the responses!
    [b]filmboss80[/]b IMHO TDK is crap media period regardless if it's geniune or not.
  30. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    I agree.
