VideoHelp.com Forum
Results 1 to 12 of 12
    Baldrick,
    With the new DST dates (that went into effect on March 11th), the board no longer reflects the correct time (it is now one hour behind).
    Is there some "switch" that you have to throw?
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Originally Posted by thecoalman
    PHPBB2 doesn't account for DST, you have to switch it manually in your profile if you are in an area that uses DST.
    Since when? It has done it properly in the past. However, it may still be set to make the change on April 1st.
    My modified phpbb version will probably switch around april 1....I'm not sure how it works...
    and the time is CORRECT...at least for us that haven't switched to dst yet.
  4. Member Bodyslide's Avatar
    I just changed the time in my Profile by an hour...
  5. Member classfour's Avatar
    Makes me want to vote for someone else.
    The changes in DST in the States has been nothing except headaches.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  6. Originally Posted by SLK001
    A standard install doesn't, you can mofdify like Baldrick. I wasn't aware that he did.
    Interestingly, changing the time in my profile corrects the time on the Forum page, but not for the latest active list on the main page. Probably will be correct once the BB software switches on its own.
    Jim - thinks DST is a ridiculous, out-dated idea and should be abolished
  8. Jim, I edited my post so no more people change it. Baldrick has a modifed version of PHBB, it's going to switch by itself if you read his post above.
    I agree DST is a PITA....
    Don't you know that cows give more milk with all the "extra" daylight? Also, crops grow more with all the "extra" sunshine!
    I did read his post.
    I'm just very "particular" about things and thus need the time to be "correct" for my location. Had to do this on a couple of other forums. And I'm sure I'll have to un-correct it on April 1.
    No worries.
    Jim
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    It has switched to dst now....I don't know how or why...
  1. Replies: 15
    Last Post: 26th May 2010, 06:45
  2. Joining Subtitles with Correct Time
    By sambat in forum Subtitle
    Last Post: 9th Sep 2009, 14:43
  3. DTS audio time not correct
    By anfield7 in forum Newbie / General discussions
    Last Post: 6th Mar 2009, 10:31
  4. Replies: 9
    Last Post: 2nd Aug 2008, 18:02
  5. Clock will not stay set to correct time
    By driley in forum DVD & Blu-ray Recorders
    Last Post: 28th Mar 2008, 00:20
