I wanted to ask what is the better choice in regards to quality and ease of use. (dvdfab platinum $49, and the later free).
I'm rather new to backing up my dvds and i have been reseaching the topic for a little while now. I have narrowed it down to using dvdfab platinum as a stand alone process or dvdfab decryptor w/ dvd shrink. The whole point of backing up my dvds are to getting to fit in a standard blank dvdr.
I've noticed that in dvdfab platinum you have to click on each title and "deselect" the language you don't want on your copy, for example the last samurai i did not want french language included so i went to customize and deselected french from each title. I was wondering if there was another way of doing it.
Thanks for the help hopefully someone will have an opinion on this topic.
Results 1 to 26 of 26
DVDFabdecrypter is my fav. prog . I'm now using the 30 day free trial of platinum, and will be purchasing soon. Some features not incl. in free edition, such as split dvd's, clone,and especially the new merge DVD feature,which I've tried on my back-ups and with good results...
DVDFab in conjunction with DVDRB pro= great results for me!!!!!
"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
Originally Posted by jcue
Personally I wouldn't go with DVD Fab at all.
I'd go with:
RipIt4Me
ImgBurn (for all DVD burning, the best!)
DVD Shrink
DVD Decrypter
All the tools you need and all are the best at what they do. And...they're all free...although a donation wouldn't hurt where possible.
@ jcue, there both good and fairly easy to use, I've used DVDFAb free for some time now,and frankly I can't remember when I used R4ME last, not to knock anything ,just personally I prefer DVDFAB.may not be the best but it works..
I will try and use whatever works for me..... and ditto on using IMG to burn! try em all and make up your own mind!!!!!"I typed the word Google into Google. Guess what came up? Everything."
wow i'm in your shoes and wondering the exact same thing jcue, im curious as to what really is better between the two. Dvd fab platinum has all the extra stuff on it phone psp stuff etc thats not needed so i dont know.
@bbanderic (or anyone that can awnser); do you prefer Ripit4me over Dvd Fab Decryptor/Platinum in terms of quality? if not what other prog for that matter??
i've tried out clone dvd and noticed audio sync issues there that's no fun
Everyone has their preferences, try them all and use what works best for you. If you want an all in one then maybe DVD Fab is for you. More often than not, all in one programs are jacks off all trades, masters of none.
If you go with DVD Fab, I still wouldn't use it for burning, ISO creation or manual layer break placement for DL DVD's. If you want quality, reliable DVD burns, ISO's, LB placement, you'll need ImgBurn.
Personally, I stand by RipIt4Me, DVD Decrypter, DVD Shrink and ImgBurn and they're all really easy to use.
bbanderic wrote, Everyone has their preferences, try them all and use what works best for you.
I agree, so try em all! AFAIC, R4ME is somewhat of a all in one,as it uses several progs in 1 click mode. I don't think the rip has too much to do with quality,it's more what u use to backup.
I personally use DVDRB ,more so than shrink, and definitely use IMGBurn! just my 2/12 cents...... 8)"I typed the word Google into Google. Guess what came up? Everything."
No you don't have to have CCE basic. It comes with the free HCEnc and QuEnc, both great encoders IMO. Their not as fast as CCE, but I do most of my backups at night ,and the quality makes a diff. for me!! I had the free DVDRB for sometime ,and cuz of the time it would take to process, I did'nt use it much.But since upgrading to PRO, I have'nt looked back!!! 8)
CCE Basic will probably give the fastest, and for most titles the best, performance, but DVD-RB doesn't require CCE, Basic or otherwise. DVD-RB comes with free encoders, and from I understand, HC rivals CCE on low bitrate sources.Originally Posted by bbanderic
I donated to the DVD-RB camp quite a while ago, and use it almost exclusively, along with Rip It 4 Me and ImgBurn.
Try the free tools for yourself and see what works best for you ... you won't have lost any money that way. When you find what works and what you like, feel free to donate as much as you can to the developer. You may not receive a license, but you may feel like you've done the right thing!
Originally Posted by t0nee1
I'll have to look into DVDRB more, in case DVD Shrink becomes obsolete. I rarely re-encode any video. On movies, with DVD Shrink, I strip the unwanted stuff and just rip the "main movie", fits on one disc most of the time without re-encode, in original quality. When it needs to be shrunk to fit, it's minimal. I would assume DVDRB doesn't re-encode all the time when not needed?
@ bbanderic, yes I normally do the same ,and get rid of unwanted stuff, except I rip full movie> then DVDRB main movie only...Unless I burn to DL, then I back it all up staight to IMGBurn w/o dvdrb or shrink, or anything that re-encodes.. but definitely look into DVDRB.
I still think shrink is a great prog. especially in re-author mode to strip and combine clips and such. And BTW, DVDRB won't re-encode, if it's not needed, it'll tell you..... if thats the case, just burn away!!!!"I typed the word Google into Google. Guess what came up? Everything."
I didn't explain myself clearly the first time...I rip the full movie as well, first > then Shrink, main movie only.Originally Posted by t0nee1
DVDRB looks very interesting and seems to have a lot of positive feedback. I'm not sure it does anything that DVD Shrink can't, or better, but it's definitely worth having an open mind about it, taking a deeper look and experimenting with it.
Thanks for the insight.
@ bbanderic,
Do you encode/or whatever it does in default mode "normal", or "slow" which gives better results supposedbly?
@ willhenderson, normally I'll use best mode( slowest) but occasionally I'll try one pass mode if I'm testing for quality and speed. but IMHO ,I can't see too much of a diff, either way, but I prefer the Best mode........
Thanks for the great feedback I really appreciate it. As of now my 30 day trial of dvdfab platinum has expired but dvd shrink and dvdfab decryptor are still free. I don't see much in the difference in quality but for convenience dvdfab platinum is easier just set to full movie w/ dvd5 option and “presto”. On the other hand dvdfab and dvd shrink will do it in two or three steps not bad but it can get tedious when you just want to set and forget it. Thanks for the help guys/gals.
Good thread jcue
And t0nee1 ah yeah "best mode" is what it is. I'm using that now being my first time i'm at 70.4% overall progress. See how it goes in the end if it plays correctly and all. I'll probably end up trying both ways as it this way takes quite some time.
the end result is well worth it and satisfying
i can hardly tell any quality loss on this converted dvd5 w/ dvd rebuilder + cce
Thats great!!! just tell me it didn't take from Mar.14 thru Mar. 22nd...LOL
quality is pretty darn good using DVDRB eh!!!
BAHAHAHAA
no man, this thread slipped under me
Best Choice: DVDFab Decrypter > DVD Rebuilder > ImgBurn
***User Rebuilder with HC Encoder, Best Quality
Great Second Choice if This Doesn't Work: RipIt4Me/FixVTS > DVD Shrink > ImgBurn
You should have all of these in your possession!
"I'm sick of paying for dinner and being served cowshit, while they give the bums eating out of the garbage my meal."
--- D. P. Smith
Considering the price - no.Originally Posted by willhenderson
There's always .. nevermindOriginally Posted by Abond
DVDFab Platinum missing 99.9% of DVD, but 100% of it shows in DVD Shrink!??
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 12Last Post: 22nd Oct 2009, 18:31 -
Presence of DVD not recognized by DVDFab Platinum
By GHal in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2008, 01:28 -
dvdfab platinum and dvd hd decrypter
By marioval in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 14:40 -
XBOX 360 converting (dvd to xvid) with dvdFAB Platinum
By devGOD in forum DVD RippingReplies: 6Last Post: 12th Dec 2007, 16:49 -
dvdfab platinum dvd to ipod audio low!!!
By Jorge in forum DVD RippingReplies: 7Last Post: 6th Sep 2007, 09:59
