I hope this is the place - anyway:
I have Pioneer DV-383 (DVD Player), and it doesnt support Packed Bitstream, so i'v been told to use MPEG4Modifier to unpack the bitstream.
and i have a few questions:
what is Packed Bitstream????
does unpacking the bitstream will reduce the video quality?
thank you!!!
Thread: Question about Packed Bitstream
My understanding is that it is a compromise method of storing the data to make playback using vfw based players work correctly. Unpacking it does not affect image quality.
Unpacking a packed bitstream has no effect on quality. It's just a matter of how the frames are packed inside the AVI file.
MPEG video constists if key frames (full pictures, I frames), forward predicted frames (encoding only the differnces between a frame and an earlier frame, P frames), and backward predicted frames (B frames). B frames can't be reconstructed until a later frame has been decoded. Some programs (mostly those based on the VFW system of Windows) can't handle this out-of-sequence decoding scheme. Packed bitstream is a workaround for this.
How to enable Packed bitstream
By john111 in forum Video ConversionReplies: 8Last Post: 4th Jan 2010, 14:17 -
it is safe to use Packed Bitstream on Xvid
By afcoff in forum Video ConversionReplies: 8Last Post: 6th Mar 2009, 07:43 -
adding packed bitstream to xvids
By pace508 in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2009, 16:10 -
Help with MPEG Modifier... Packed Bitstream...
By GangstaRap in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2007, 12:14 -
Phillips DVP59A8 -- DivX w/USB (good for packed bitstream?)
By ZoneRanger in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Sep 2007, 22:27
Statistics
Newest guides
Latest tool updates
New media comments
