How can i copy a protected DVD? When i simply copy it, it says it is protected. Usually i back up the dvd and then burn the image file. I have been using DVD SHRINk to copy it. Unfortunally it's not working now... Any suggestions?
Results 1 to 23 of 23
Thread: How to copy a protected DVD?
You need to update. dvdshrink isn't updated anymore.
ripit4me
dvdfabdecrypter
those are two current freebies generally used here
anydvd is payware that is updated regularly also.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
what program shud i use to burn it after backing it up with dvdfabdecrypter ??
well dvdfabdecrypter only copies it to your harddrive. You need to use something like imgburn.
You can also use old dvddecrypter for burning in conjunction with dvdshrink AFTER you rip the disc to the harddrive. They are still useful tools they just aren't updated anymore for the newest protection schemes.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Thanks alot for all your help!!
Set it to build mode, and make the target a disc instead of an ISO
It still doesn't seem to work, i go to build mode, then what? Does it write it as a iso file?
You have some proof of this, of course ?Some dvd have laser marking at the inner edge which you can mask with toothpaste or a dry wipe marker pen. Hey presto the dvd can now be ripped by many software including dvdshrink.
Putting a disc smeared with toothpaste in my player seems like a great idea. Maybe peanut butter would work better?
LOL
I think mauricefra is confusing some CD audio copy protection with DVD copy protection. Because some audio CDs with copy protection were manufactured as hybrid discs (they appear to be CD-ROMs to PCs but normal audio CDs to CD players), it was supposedly possible to mess up the data part of the disc, which would become unreadable on a PC and force the PC to treat it as a normal CD audio disc. There are better ways to defeat CD audio copy protection than this.
Yes i have copied many protected dvd's e.gthe movie "Transformers" and "Gregorian the Masterpieces(LIve in Prague)". If you want to use toothpaste, wait till it dries or as I said use a dry wipe marker pen. Just look at the DVD for the tell-tales marks. The protection can also be on the outer part of the DVD as well as on the inner ring.Works 100%.
your "transformers" movie is most likely not protected to begin with...
I am just a worthless liar,
I am just an imbecil
Then it's a gritty powder. Just what I want on a disc spinning at thousands of RPM, flinging grit into the works.Originally Posted by mauricefra
DVD Box actually said Protected DVD. I have tod you guys you can also use a black marker pen. Someone asked a question and i gave the solution. Anybody can LOL but it works. You have to pysically mask the Laser protection when software doesn"t work.Originally Posted by TooLFooL
There is no laser protection. Period. Now, let's talk about UFO's and the JFK assassination.
Thanx to all those who answered this question. I too have just figured it out from your help
I have tried blanking out (with a CD/DVD Marker Pen) the coding on the inside ring of a DVD - which I assume is the copy preventative coding. Using Roxio to copy disc it still comes up that the DVD is copy protected. Any more suggestions? Any help most appreciated.
The copy protection is built into the way the disc is encoded, as well as encryption codes pressed into the disc itself. No amount of colouring in with a sharpie is going to make any difference. Start your lessons here : http://forum.videohelp.com/threads/2...-DVD-Decrypter
Copy Copy-Protected VHS to DVD
By abazabam in forum MediaReplies: 36Last Post: 12th Feb 2012, 02:25 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
copy protected DVD
By marcelcukier in forum DVD RippingReplies: 12Last Post: 7th Oct 2008, 09:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
