Was the HDMI ... connected ??Originally Posted by dork4638
Cant have both the same time ... bummer huh ??
Results 91 to 120 of 210
Okay, I was wondering if someone could please help me. I want a Philips DVP5982. I have the DVP5960 and love it. For those of you who don't know, the problems out of the box with the 5960 are: You can't ust the digital audio coaxil output while using HDMI (in a nutshell, if you want to use HDMI to get the upscaling, you can't get digital audio on an external amplifier. It only carries the digital audio through HDMI while HDMI is in use), it doesn't support DTS and the USB playback from external hard drives is somewhat limited because it is USB 1.1, meaning that if you play files using a higher bit rate (above 3000 kbps) it stutters. ALL of these problems were rectified after using the firmware upgrade on Philips' website.
Here is the 5960 firmware upgrade.
http://www.p4c.philips.com/cgi-bin/d...=Link_Software
Now what I want to know is: does the 5982 have the same issues and do they all get fixed with the 5982 firmware upgrade on philips' site? And is the USB connection still USB 1.1 and if it is, does it perform better? I've seen some links on here and some contradict each other, is anyone saavy enough to answer these questions? It would be amazing if someone could.
Here is the page with the 5982 firmware upgrade.
http://www.usasupport.philips.com/pr...SU_US_CONSUMER
Even the USB high bitrate problem?Originally Posted by conanada
Lacywest,
While I cannot speak for dork4638, I cannot use the dvd player's HDMI port since none of my entertainment system (A/V receiver and the TV itself) do not have such connections.
So, I cannot see why this player would show video when I hook it directly to the tv and NOT when I hook the player to the A/V receiver instead.
I was extremely careful in the hookups to assure everything was going to the correct ports/connections.
I do not (yet) have tv's or receivers with HDMI. Shouldn't need any of that at this time just for this player.
Strange.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
It did not fix the USB bitrate problem, no.
I want to know if the unit will output digital audio (DTS especially) from the coaxil output if the HDMI is hooked up. I would also like to know if the USB connectivity is better/faster than the 5960.
cheers!
Thanks for the input, I was hoping that someone who has this player AND has it connected with HDMI, with an A/V receiver hooked up via the coax digital connection could give me the scoop.Originally Posted by painkiller
Anyone?
The USB? Does it perform better than the 5960?
I'm going to buy the player and test it out today and let y'all know what the scoop is.
Hopefully I can give some useful information.
Yes I bought the DVP5980 for watching dvds upscaled as my number one reason. I also questioned myself wether I could watch dvds via hdmi yet simultaneously use the analog sound out to listen to audio via external speakers and it turns out this works perfectly well. I disabled the tvs inbuilt amp so the 2 dont clash, altho this is not a necessity as you can mute the tv sound if you want to use the external speakers. Great job of upscaling and also plays divx perfectly via the usb. I cant recommend this dvd player highly enough, am very happy with it.
I got the DVP5982 a few days ago (be careful of Best Buy's deceptive online pricing - the prices at the store are often higher).
I don't have a high def tv yet so I mostly got it because I read a lot of comments about this player being able to play many video formats. I have a ton of avi files of tv shows, mostly DivX, and they most likely range in quality and encoding methods (I don't know much about that area either).
I've played 2 commercial DVDs, 2 DVDs that I recorded myself from avi files and a bunch of DivX avi files directly from DVD-RW disks and from a generic no-name 4GB USB stick. No problems yet when played to a regular tv set.
However, the limitation of the On Screen Display that can't show the whole file name of DivX files is a major shortcoming. I read somewhere on this board that it has to do with the licensing of the long file name method of FAT file systems that Micro$oft holds.
If anyone knows of any hack that allows the OSD display to show the whole file name, either on the index screen or on the screen when it shows time elapsed/remaining, that would be a major improvement in the usability of this player.
I can return it to the store and get something else but at this low price level (since I won't be viewing HD content any time soon) is there any other comparable player that will play various video files as well as this and has a better user interface?
Thanks for any information and/or suggestions.
I just got the 5982 and it's been awesome. The only thing I wish it had was the long file names!!!
I have noticed:
-USB port play movies off my flashdrive much better than my old Divx with a USB 1.1. I always thought it was a USB 2.0, and I'm assuming it is but I've never tried a external hard drive with it. They do make it hard to find the "true" answer tho. The maual says it provides 500mA of power (which is USB 2.0 I believe)
-The remote is still a 'brick'. Hard to figure out which end to point at the player when it's dark.
-Turning on the unit and getting to the point of being about to play something takes a few seconds - it's definitely not instantaneous - but I may just be impatient. :]
-No long file names
Other than the above negatives this unit is fantastic. Looks good, upscales, plays everything I've thrown at it (including a few qpel vids). Very happy with it.
If you have any questions about the 5892, don't be afraid to ask. If the questions are "too" technical, I won't even know what you are talking about! I'll try to help tho.
Originally Posted by Hank Kinsley
I suspect no is the answer but wanted to see if it's been tried. Can .vob files be played from the USB port on the 5982 or is it like the 5960, not fast enough to handle the high bitrates required.
I have never tried a .vob file but if you let me know where I can get a test .vob file, I can try it on my Flash Drive.
Rip one off a DVD. I know that high bitrate VOB files do not play smoothly on the DVP 5982. It might still be better than the 5960 though.Originally Posted by Hank Kinsley
VOBs didn't play good for me. The 5982 is better then the 5960 but if you want to play VOBS from a DVD put on a DVD.
Okay, I have some answers regarding this player.
IT IS NOT USB 2. It it better than the 5960 but is still lame if you have higher bit rates that you want to play via the USB input. FOR EXAMPLE... If you download or rip a movie that is about 700 megabites, with prologic surround, it works well... If you have a higher video bit rate with DIGITAL AUDIO, 5.1. AC-3, DTS, etc. It STUTTERS BAD HOWEVER, if you rip the movies and burn them on to a DVD, it plays just about anything you throw at it AND it plays it WELL.
IF YOU HAVE THE HDMI HOOKED UP, THE DIGITAL COAXIL OUTPUT DOES NOT WORK.
From what I'm told, it does not support DTS. I was going to test it but decided to pack it up and take it back once I found out that the digital coax doesn't work if the HDMI is hooked up so that means: YOU CAN'T SEND THE DIGITAL AUDIO SIGNAL TO A SEPERATE RECEIVER AND HAVE THE 1080I/P UPSCALING AT THE SAME TIME!
This player is good. I have the 5960 and when I added the firmware, the DTS was activated, the coaxil output works when the HDMI is hooked up while upscaling. From what I can tell, it's virtually the same DVD player as the 5960 with slightly better USB playback for MPEG, DIVX, XVID, etc. AND they ablity to do the 1080p upscaling.
I might take the 5982 back and try the new Pioneer, they tell me it has USB 2... so we'll see. I'll keep y'all posted.
I think I'm pretty well versed in the player now, so if anyone has any questions... I have a 5 year back ground in A/V gear and installation... I'm cool with trying to help out.
Just some additional info for Peeps . I have the 5980 and was most interested for the divx ultra which doesnt seem to get much of a mention. The claimed features work (havent tried subtitles at all) the files I used were pre-encoded avi's which were run thru divxmediabuilder and saved as xxxx.divx . ALso I created a 2.5gb file which I burnt to a UDF disc using Nero and that played fine. In fact it seemed a liitle quicker than ISO. I havent yet tested the claim of a maximum of 648 titles supported.
Also the player shows a 14 char filename (or the first 14 chars) better than the claimed 8.3
it also shows a much longer directory name up to 40 characters
big up de man for divxmediabuilderCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
im guessing external harddrives wont work?
Yes, they do. Read through the thread.Originally Posted by cudencuden
Could you include some info about the Pioneer ?? ... What model number ??
I think he is talking about the Pioneer DV-400VOriginally Posted by lacywest
thanks a lot..cant believe a free program like swiss knife works better than the paid partition magicOriginally Posted by jagabo
This is the Pioneer I was writing about.
http://www.pioneerelectronics.com/pn...756832,00.html
That looks like a very nice player.
Anybody have experience with it? I'd be particularly interested in how well it's DIVX handling performs.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
http://www.avsforum.com/avs-vb/showthread.php?t=841054Originally Posted by painkiller
The region free hack for that player does not appear to be as simple as a few button presses on the remote.
http://www.videohelp.com/dvdhacks/pioneer-dv-400v/8351
Thanks, MJA. Much appreciated.
I just bought the DVP5982. I m having hard time playing divx files i download from Stage6divx. Like i downloaded Bleach Memories of Nobody for my cousins and when I try to watch it keeps loading..the Reading Index box does not appear. Does anyone know what i have to do? I already activated the VOD crap. I was trying to play it VIA the MiniHardDrive i had plugged into the USB direct port. Can someone advise?
I have had the 5982 for a while and have had no complaints apart from the remote control design and the slow speed it takes to read discs.
I recently updated the firmware, and unfortunately I didn't wait out the full 5 minutes for the upgrading. I powered the unit off, and now it won't do anything? I know it wasn't smart, but does anybody know what I should do? Will a factory reset work? I don't even know how to do that.
Any advice would be appreciated.
Just wanted to let you guys know there is a newer firmware for the 5982 released 10-30-07.
http://www.usasupport.philips.com/co...SU_US_CONSUMER
Details:
The upgrade version of this software is Version 37.07.32.43
This software version includes:
• HDMI to DVI TV: resolve set losing resolution setting upon standby.
• Set HDMI Audio setting default to ON
• Improve HDMI Compatibility
That new firmware update also I believe has cured the packed bitstream playback issues.
Gary Tabar Jr.
Philips DVP5982/37 USB file question
By kme06d in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jun 2011, 17:09 -
Philips DVP5982 Compatible USB Flash Drives
By Nikephoros in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Mar 2009, 00:34 -
Philips DVP5982 USB FYI
By 403gl in forum DVD & Blu-ray PlayersReplies: 5Last Post: 1st May 2008, 07:53 -
Philips DVP5982 - USB hard drive folders not all showing
By PunkHippie in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Sep 2007, 12:58 -
Philips DVP5982 USB & StaxRip
By Trac in forum DVD & Blu-ray PlayersReplies: 10Last Post: 17th Sep 2007, 11:20
