Okay, its been a long time since I last posted. Anyway here is my question...
I'm wanting to upgrade the CPU in this current machine to a dual core. This machine is being used primarily as a workstation and is doubling as a low level dedicated server. I'm on a budget of 250 USD for the CPU and I have narrowed it down to three choices.
http://www.newegg.com/Product/Produc...82E16819103544
http://www.newegg.com/Product/Produc...82E16819103527
http://www.newegg.com/Product/Produc...82E16819103584
My question is which of these three will best suit my needs? I do alot of audio and video processing Adobe Premier, Avid, Cakewalk etc. Occasional gaming, this processor will be overclocked so I need one that overclocks well. I'm wanting to pull as much performance as I possibly can out of a dying socket 939 motherboard.
Thread: CPU advice needed
:ונעדי ימ אוה שנאו לכמ בלה בקע
In general, most video encoders are multithreaded these days so a dual core will be signifantly faster than a single core processor. Cache size doesn't make much difference with Video encoding. Clock speed makes a bigger difference than cache size.
http://www23.tomshardware.com/cpu.ht...=476&chart=185
Of course, this varies from application to application.
http://www23.tomshardware.com/cpu.html
Thankyou for the benchmarks jagabo, They will definitely help me in my decision.
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Need Advice on Upgrading CPU
By AuroEdge in forum ComputerReplies: 19Last Post: 26th Oct 2009, 01:22 -
Low CPU Intensive video codec needed
By fitch.j in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 04:40 -
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 19:55 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
Statistics
Newest guides
Latest tool updates
New media comments
