Dear forum
Please does anyone know if I can watch videotapes by playing them via VCR player connected not to a telly, but to a computer. also how would I do this please
Yours with thanks
Ian
ian c
If your computer has a video input, yes you can. If you don't have a video input, either on the video card, a separate capture card, a TV card or an external capture device, no you can't.
Dear Sir
Thank you for this. Ive looked at the rear of the PC and the cards.
There is no capture card or tv card.
Is the video card the one the monitor cable is plugged into . If so theres no video input socket on it.
Yours with thanks
Ianian c
In that case, you need something like this
http://svp.co.uk/products-solo.php?pid=1196
or
http://svp.co.uk/products-solo.php?pid=1200
Dear Richard
Thanks again for this advice. The pinnacle dazzle dvd recorder seems just the job. the only problem as far as I can see is that the minimum spec PC is a USB 2 port.
My PC (amd athlon 2000 chip running at 1.67 gigabyte ) as far as I know has only USB 1.
Please do you know if this would do, or , if not , what other solution to this problem might exist
I liked the PCI card for freeview capture. I already have a usb dvb-t dongle which does same function . Please do you know if PCI card is better than the typical usb freeview dongle.
Yours with thanks
Ianian c
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
analogue video from VHS tapes to PC
By teka1 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 09:32 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum CapturingReplies: 1Last Post: 10th Sep 2010, 16:27 -
Video restoration for 10-20yrs old VHS tapes
By thegunstop in forum RestorationReplies: 19Last Post: 1st Apr 2010, 09:56 -
Problems capturing analog video from VHS tapes
By jdwmba in forum CapturingReplies: 8Last Post: 15th Mar 2008, 17:52
