VideoHelp.com Forum
    Got myself a PVR 3000 yesterday and it works ok, great quality, except one little thing... i cant get the sound to work correct.
    I found out after 6hours of reading, re-installing and even more reading that the sound is actually there... only extremly low.
    I was able to start with louder sound if i checked this box
    and i also had to started with Winamp running in the background. BUT, if i did that i also got a delay on almost 1 second on the joypad while playing on any system.
    As you can see on the picture iam running a inbuilt soundcard (VIA, yea i know) - so, i would like to know if anyone else have the same experience or if you are 100% certain that its all a question of getting a PCI-soundcard? I'm currently using latest driver/software from leadtek.com.tw
    All tips and trix are welcome, thanks.
    Hi, firstly sorry for my English but I have learnt only 6 mounths . I bought PVR 2000 and I have exactly the same problem as you. During recording or even watching using preview hardware encoding I haven't any sound. I think this is problem in WinFast PVR 2 program because when I use WinFast PVR - hardware encoding is ok (but this interface is so-so). I find also another problem. When I schedule recording and then try to hibernate or stand-by machine - it doesn't work . Do you have similar problem ?
  1. Slight Hauppauge HD PVR Issue
    By octaneflame in forum Capturing
    Last Post: 10th Feb 2011, 16:46
  2. Capturing SD 4:3 Movies with HD PVR
    By turbines in forum DVB / HDTV
    Last Post: 23rd Apr 2010, 07:46
  3. Hauppauge HD PVR capture and jerky video issue
    By Split Infinity in forum Capturing
    Last Post: 10th Apr 2010, 07:27
  4. Any OTHER S/W for Capturing a DH-PVR?
    By Randall_C in forum Capturing
    Last Post: 22nd Oct 2009, 12:55
  5. Replies: 2
    Last Post: 11th Oct 2008, 16:33
