Just wondering if this software is still under development?
Haven't seen any new updates for about 6 months and have had a few issues with it, which has meant I rarely use it now (moved to convertx2dvd) but if it is to be updated then will maybe stick with it for a wee while longer as I like being able to join films together easily and the simple but very effective menu system...
Results 1 to 30 of 76
Thread: Still under development?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Ok, thanks guess it still is ... eventually.
think I'll stick with converrtxtodvd for now as no errors as yet.
Thanks for the reply
hope it works out.
Well yes I have a new version "in the wings" which is an update to the "current" version, with several bug fixes, improved GUI, new features and .Net 2. That will be released shortly.
I then have a new build in development which is a quantum leap from where the tool is today.... but that is a bit of a way off at the moment.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
That's good to hear CB, will keep an eye out for it...
Thanks for letting us know
I'm glad to hear you're still updating this. I was starting to worry since it's been so long since the last update. For a while there the updates were fairly frequent so I guess I got used to that. Hopefully we'll see the return of burn to image support and support for H.264 audio?
H264 audio? h264 is a video codec...
Yes video my mistake.
HI CB, any more word on this m8?Originally Posted by ChrissyBoy
Honest_geezer
Yes. I have a version ready for "testing". Drop me an email and I will send you a link (include reg serial please). Noticeable changes are:
- .Net 2 build
- Improved Vista compatability
- More formats supported: aac, mkv, h264/x264, dts
- Undo/Redo added to menu designer
- Improved encoding quality (no real need for 2 pass now)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hey ChrissyBoy, can u pls send me also the link, I would like to test. I´m a registered member of your fantastic tool.Originally Posted by ChrissyBoy
PM on the way.
thanks
Sure.
thanks for the link ChrissyBoy, yesterday I tried and worked fine, but I was looking for the logs after finishing and couldn´t find, where are the logs saved now?Originally Posted by ChrissyBoy
Here:
Whatever happened to the switch that was to be made available to select between full D1 and half D1, Chrissyboy? It's a pain doing it in the registry. You had said that you would put that option in a future release, oh about 2 years ago.
Mark
You mean the threshold value? Or a "force" flag?
CB, could you please also send me a link to new test build too as I seem to be also having a few probs of late with current build.
PM sent, many thanks!
Sure
CB could i have that latest release to check out too? PM sent cheers m8.
Not got anything - want to resend?Originally Posted by rebelinkSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
pm sent cb
any chance of trying svcd2dvd 2.5
CB-
PM'd you yesterday about trying "2.5", but...?
That "2 pass encoding not needed " feature has my attention!
CBC: - PM not received! Try again mate or drop me an email. Sorry about that.
just tried the new beta version i must say im impressed so far theres at least a 30 to 40 percent speed improvement. using it on vista ultimate installed without any problems. thanks keep up the good work chris.
Using on WinXP, working excellent, much faster. Grateful for the H264/AAC support.
Great work!!Dwight
- Herm Albright
Hi,
Can you please send me the link for the beta version.
Cheers
John
Can i try it also please.
pm sent.
Can i try v2.5 also please. I´m a registered user.
Thank you!
Hi Chrissy,
Would you please be so kind and send me the download link for the 2.5 beta?
Thx and best regards,
Uwe
Hey CB, thanks for the 2.5 link. It works great on my XP64 Dualie, but it won't run on my W2K Dualie. V2.1 works fine on both machines. When I run it on the W2K machine i get (file below)Originally Posted by ChrissyBoy
Weird?
Also, will neroburner be an option in the new version? I don't mind having to run Nero seperately, but it would be nice not to.
TPM
MKV2AC3 - development thread
By Delta2 in forum Newbie / General discussionsReplies: 90Last Post: 24th May 2012, 13:31 -
GfD development version
By borax in forum ProgrammingReplies: 136Last Post: 9th Nov 2011, 17:01 -
Is TSSniper still under development?
By The Realms of Gold in forum EditingReplies: 4Last Post: 29th Apr 2011, 17:33 -
Is ffmpegX still in development?
By reviltihco in forum ffmpegX general discussionReplies: 5Last Post: 13th Aug 2010, 10:54 -
My gratitude for development
By plasmacutter in forum ffmpegX general discussionReplies: 0Last Post: 1st Jan 2008, 06:30
