VideoHelp.com Forum
    my connection looks alright but i still get some light pixely signal loss. it is very noticeable on some of my finalized dvds (i usually record in xp and dub in flex mode...usually 2 hour discs). is there anyway i can improve my connection for a better quality hookup?
    here is my current connection:
    DirecTV Receiver to VCR (AV Cables...yellow white red)
    VCR to Panasonic DVD Recorder (AV Cables...yellow white red)
    DVD Recorder to TV (AV Audio Cables and Monster Cable S-Video)
  2. Member Krispy Kritter's Avatar
    The fewer connections the better. For instance, if you are recording from the DirecTV to the recorder, hook it up directly. Any cable and input/output connector can reduce quality. Also, composite outputs (yellow cable) are the lowest quality you can use.
    In order of quality, worst to best: composite (yellow), s-video, component (red/green/blue), DVI/HDMI.
    If you really need all of that equipment hooked up in that way, about the only thing you can really change is cables.
    Google is your Friend
  1. Connection help please! HDD Recorder, SKY TV to TV
    By sarahholland in forum DVD & Blu-ray Recorders
    Last Post: 16th Apr 2011, 06:38
  2. Connection setup for a STB and HDD recorder
    By garyasta in forum DVD & Blu-ray Recorders
    Last Post: 8th Mar 2011, 22:32
  3. A DVD recorder with a USB Direct connection that allows Dvix and Xvid
    By Conercao in forum DVD & Blu-ray Recorders
    Last Post: 6th Dec 2008, 12:22
  4. Interesting Connection Problem. LG DVD Recorder to Samsung LCD TV
    By kramsey999 in forum DVD & Blu-ray Recorders
    Last Post: 21st Oct 2008, 01:13
  5. Connection between PC and DVD recorder
    By mish159 in forum DVD & Blu-ray Recorders
    Last Post: 3rd Jun 2008, 19:29
