Can you help, i burned a film onto a disc and there was no sound. Before i burn the film i converted it into video ts Vts etc so i could put it through dvd shrink..
Also there seem to be 2 vob files in there, could that be the problem wuith the sound, i've checked that my volume was not on mute as i was getting sounds from everything else.
If you need it i can give you a screen shoot of what i got n my folder.
Thanks.
Thread: No Sound After Burning
Sorry whilst I'm on this subject Ive got another DVD that is in iso format. Would i be able to burn this in its format or would i have to convert it.
i have got power ISO that has a burning tool in it should i use that.
Thanks.
You can burn ISOs with ImgBurn, which I would recommend for burning VIDEO_TS folders also. Use the latest version. It's freeware. For VIDEO_TS folders, use the 'Build' mode.
A VIDEO_TS folder can have as many VOB files as needed. They are set at a 1GB size, so most DVDs converted with Shrink have four or five. A commercial DVD will have more, depending on size. For the DVD format, look to the upper left on this page in 'WHAT IS' DVD.
If you are playing the finished DVD on your computer, you may not have the proper audio codecs installed. Try playing with VLC Media Player as it uses it's own codecs. Nothing to install.
Thanks for getting back, I've just done a check and for some reason the films I've got on my HDD the sound will only play on Divx player witch i only installed 2 days ago. Before i installed divx player i had no problem with the sound.
I was able to play the films on any other player, ie windows media player media player classic etc. And had no problem with burning
Could the divx player be causing the problem ?
Tony L - This forum is for VCD/SVCD issues and your problem is with DVD authoring. You should have posted it in the DVD Authoring forum.
Is there a moderator who can move this thread to the correct forum?
Burning a bluray but no sound..
By malmsteen in forum Video ConversionReplies: 9Last Post: 19th Feb 2012, 16:16 -
No Sound on BURNING
By mufpot in forum AudioReplies: 4Last Post: 10th Aug 2009, 13:39 -
No sound after burning
By janlafata in forum Newbie / General discussionsReplies: 6Last Post: 22nd Dec 2008, 16:21 -
By fazza8 in forum Authoring (DVD)Replies: 10Last Post: 30th Jun 2008, 05:58 -
Sound problem burning DVD+R
By captspalding1 in forum DVD RippingReplies: 9Last Post: 2nd Dec 2007, 10:48
