VideoHelp.com Forum
  1. I have a 2 channel speaker connect to my SoundMax onboard audio. When I play Hollow man II DVD movie, I only hear the rear speaker sound. I have double checked the physical connections and the speaker is connected to the front out jack. When I play traliers from the same DVD, I have no problems.
    The problem even occurs witht the front panel audio jack. Please help!
    I'm using media player 11 and latest driver.
  2. Member waheed's Avatar
    DVDs are usually 5.1 surround sound audio, so you need to go into the media player settings and change the speaker configuration from 5.1 output to 2.0 speaker output (and also your sound properties from control panel)
    Trailers are usually encoded in 2.0 output which is why they will play fine.
    Also: Control Panel -> Sounds and Audio Devices -> Volume tab -> Speaker Settings box -> Advanced -> Speakers tab. Select your speaker configuration.
  1. DVD-R sound coming through only one speaker
    By Marshfish in forum Newbie / General discussions
    Last Post: 7th Sep 2011, 01:40
  2. Edited sound jumps from speaker to speaker
    By len hend in forum Audio
    Last Post: 23rd Jul 2010, 05:49
  3. AC3 filter rear speaker problem
    By HaCKer_52 in forum Audio
    Last Post: 22nd Mar 2009, 10:52
  4. Replies: 2
    Last Post: 11th Jul 2008, 09:11
  5. Replies: 5
    Last Post: 31st Dec 2007, 21:25
